Dell PRO 14 PLUS PB14250 U7-265U 16
Quicklinx: JH2JWS00 Mfr#: 93XNY
More than 50 In Stock
£1,076.34 ex VAT
£1,291.60 inc VAT
Standard delivery Delivered within 3-5 working days
The Dell Pro 14 Plus PB14250 is designed to enhance productivity with robust features and performance. It boasts a 14-inch Full HD Plus display, capable of resolutions up to 1920 x 1200, ensuring clear visuals and vibrant colors. The anti-glare IPS technology provides a wide viewing angle, making it suitable for collaborative work and media consumption. Alongside the impressive visual capability, the laptop integrates a powerful Intel Core Ultra 7 processor that supports multitasking with its 8-core design, reaching clock speeds of up to 5 GHz. The solid-state drive (SSD) with 512 GB capacity ensures quick boot-ups and rapid data access, significantly improving workflow efficiency. With capabilities such as ExpressCharge and advanced thermal management, this device is engineered to perform reliably in various environments while being environmentally conscious with ENERGY STAR certification and EPEAT Gold level compliance. The audio experience is enriched by dual noise-canceling microphones and stereo speakers, making video calls clearer and media playback enjoyable. The integrated RGB camera with Temporal Noise Reduction adds to the user experience, offering crisp images at 1080p resolution. For connectivity, it features multiple USB-C ports with Power Delivery, HDMI, and Bluetooth support, allowing seamless integration of peripherals and accessories. The combination of security features, including a fingerprint reader and TPM 2.0, ensures data protection and privacy for users. The Dell Pro 14 Plus PB14250 stands as a reliable companion for professionals seeking a balance of performance, portability, and security in their computing experience.
Dell Pro 14 Plus PB14250 - 14" - Intel Core Ultra 7 - 265U - vPro Enterprise - 16 GB RAM - 512 GB SSD
Notebook
Operating System
Win 11 Pro
Platform Technology
Intel vPro Enterprise
Intel Core Ultra 7 (Series 2) - 265U / 2.1 GHz, up to 5.3 GHz / 12 MB Cache
Neural Processor Unit (NPU)
Intel AI Boost - up to 12 TOPS
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
14" 1920 x 1200 / Full HD Plus @ 60 Hz - 162 ppi
Graphics
Intel Graphics
Keyboard Backlight
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
3-cell
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Platinum silver
31.35 cm x 22.4 cm x 2.12 cm
1.53 kg
Pricing Type
Build To Stock (BTS)
Manufacturer Selling Program
Dell Smart Selection
Environmental Standards
ENERGY STAR Qualified EPEAT Gold, EPEAT Climate+
Carbon Footprint
108 kg carbon emissions
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 11 Pro
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 2) 265U / 2.1 GHz
Max Turbo Speed
5.3 GHz
Number of Cores
12-core
Performance Cores
2
Efficient Cores
10
Cache
12 MB
Platform Technology
14 Threads
Intel AI Boost
NPU Performance Up To (TOPS)
12 TOPS
AI Datatype Support on NPU
INT8
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WindowsML, ONNX RT
Windows Studio Effects Support
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
5600 MT/s
Rated Speed
5600 MT/s
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
14" - IPS
Resolution
1920 x 1200 (Full HD Plus)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
162
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, 35 ms response rate, 0.157 mm pixel pitch
Audio & Video
Graphics Processor
Intel Graphics
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), Express Sign-In, camera shutter
Sound
Stereo speakers, 2 digital microphones
Codec
CS42L43
Input
Keyboard, touchpad
Keyboard Backlight
Copilot key
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Dual stream (2x2), 4G capable
3-cell Lithium Ion
220 g
55 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 Watt, 5/9/15/20 V
Connections & Expansion
Interfaces Details
HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort 2.1 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack , LAN (RJ-45)
Software
Software Included
Activate your Microsoft 365 for a 30 day trial, Intel Connectivity Performance Suite, Dell Additional Softwares
Platinum silver
Case Material
Aluminum
Security
Chassis intrusion detection, ExpressCharge, ExpressChargeBoost, Dell ControlVault 3 +, Intel Rapid Storage Technology
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter, POD Label
FIPS 140-2, TCG Certified
Pricing Type
1.53 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
EPEAT Climate+
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
77
Logistics (kg CO2e)
4
Use (kg CO2e)
24
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
83
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
JH2J Dell DELL PRO DOCK - WD25 In Stock £151.76
JH2J Dell Pro Smart Dock SD25 - docking station In Stock £206.18
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
JH2J Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - 2 years - 2nd/3rd year - on-site In Stock £60.54
JH2J Dell 1Y BASIC ONSITE TO 3Y PROSPT In Stock £153.31
Other bundles (30)
JH2J Dell Slim DW316 USB External DVD Drive In Stock £36.19
JH2J Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £8.69
JH2J Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £12.80
JH2J Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £23.31
JH2J Dell KB-813 Smart Card Reader In Stock £45.62
JH2J Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.22
JH2J Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £40.12
JH2J Dell SB521A Magnetic Sound bar In Stock £30.78
JH2J Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.08
JH2J Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £57.37
JH2J Dell Dual Monitor Stand - MDS19 In Stock £124.19
JH2J Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £43.95
JH2J Dell WEBCAM - WB3023 In Stock £42.56
JH2J Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £13.54
JH2J Dell Dell Adapter USB-C to HDMI/DP with Power Pass-Through - Adap In Stock £32.73
JH2J Dell Dell Speakerphone SP3022 In Stock £61.06
JH2J Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £182.01
JH2J Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £354.19
JH2J Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £87.02
JH2J Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £157.70
JH2J Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £278.61
JH2J Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
JH2J Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £106.88
JH2J Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £140.99
JH2J Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £217.26
JH2J Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor In Stock £275.21
JH2J Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £466.40
JH2J Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £192.99
JH2J Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £247.03
JH2J Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £89.33
Brand: Dell
Price Range Ex VAT: £1000 - £1500
