The Dell Pro 14 Plus PB14250 is designed to enhance productivity with robust features and performance. It boasts a 14-inch Full HD Plus display, capable of resolutions up to 1920 x 1200, ensuring clear visuals and vibrant colors. The anti-glare IPS technology provides a wide viewing angle, making it suitable for collaborative work and media consumption. Alongside the impressive visual capability, the laptop integrates a powerful Intel Core Ultra 7 processor that supports multitasking with its 8-core design, reaching clock speeds of up to 5 GHz. The solid-state drive (SSD) with 512 GB capacity ensures quick boot-ups and rapid data access, significantly improving workflow efficiency. With capabilities such as ExpressCharge and advanced thermal management, this device is engineered to perform reliably in various environments while being environmentally conscious with ENERGY STAR certification and EPEAT Gold level compliance. The audio experience is enriched by dual noise-canceling microphones and stereo speakers, making video calls clearer and media playback enjoyable. The integrated RGB camera with Temporal Noise Reduction adds to the user experience, offering crisp images at 1080p resolution. For connectivity, it features multiple USB-C ports with Power Delivery, HDMI, and Bluetooth support, allowing seamless integration of peripherals and accessories. The combination of security features, including a fingerprint reader and TPM 2.0, ensures data protection and privacy for users. The Dell Pro 14 Plus PB14250 stands as a reliable companion for professionals seeking a balance of performance, portability, and security in their computing experience.
- Dell Pro 14 Plus PB14250 - AI PC - 14" - Intel Core Ultra 7 - 265U - vPro Enterprise - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook - AI PC
- Operating System
- Win 11 Pro
- Platform Technology
- Intel vPro Enterprise
- Processor
- Intel Core Ultra 7 (Series 2) - 265U / 2.1 GHz, up to 5.3 GHz / 12 MB Cache
- Neural Processor Unit (NPU)
- Intel AI Boost - up to 12 TOPS
- Memory
- 16 GB DDR5 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 14" 1920 x 1200 / Full HD Plus @ 60 Hz - 162 ppi
- Graphics
- Intel Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Battery
- 3-cell
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Platinum silver
- 31.35 cm x 22.4 cm x 2.12 cm
- 1.53 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold, EPEAT Climate+
- Carbon Footprint
- 108 kg carbon emissions
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- AI Level
- AI PC
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core Ultra 7 (Series 2) 265U / 2.1 GHz
- Max Turbo Speed
- 5.3 GHz
- Number of Cores
- 12-core
- Performance Cores
- 2
- Efficient Cores
- 10
- Cache
- 12 MB
- 14 Threads
- Intel AI Boost
- NPU Performance Up To (TOPS)
- 12 TOPS
- AI Datatype Support on NPU
- INT8
- Sparsity Support
- AI Software Frameworks Supported by NPU
- DirectML, OpenVINO, WindowsML, ONNX RT
- Windows Studio Effects Support
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 5600 MT/s
- Rated Speed
- 5600 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 PCIe 4.0 - NVM Express (NVMe)
Display
- 14" - IPS
- Resolution
- 1920 x 1200 (Full HD Plus)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 162
- Image Aspect Ratio
- 16:10
- Image Brightness
- 300 cd/m²
- Horizontal Viewing Angle
- +80 / -80
- Vertical Viewing Angle
- +80 / -80
- Colour Gamut
- 45% NTSC
- Anti-glare, Wide Viewing Angle, 35 ms response rate, 0.157 mm pixel pitch
Audio & Video
- Graphics Processor
- Intel Graphics
- Camera
- Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
- Resolution
- 2.07 Megapixel (standard), 0.23 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), Express Sign-In, camera shutter
- Sound
- Stereo speakers, 2 digital microphones
- Codec
- CS42L43
Input
- Keyboard, touchpad
- Copilot key
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Dual stream (2x2), 4G capable
- Technology
- 3-cell Lithium Ion
- 220 g
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt, 5/9/15/20 V
Connections & Expansion
- Interfaces Details
- HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort 2.1 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack , LAN (RJ-45)
Software
- Software Included
- Intel Connectivity Performance Suite, Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
- Platinum silver
- Case Material
- Aluminum
- Security
- Chassis intrusion detection, Intel Rapid Storage Technology, ExpressCharge, ExpressChargeBoost, Dell ControlVault 3 +
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter, POD Label
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.53 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- EPEAT Climate+
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 76.896
- Logistics (kg CO2e)
- 4.536
- Use (kg CO2e)
- 24.516
- EOL (kg CO2e)
- 2.052
- Total Carbon w/o Use Phase (kg CO2e)
- 83
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Dell DELL PRO DOCK - WD25 | In Stock | £148.54 |
Dell Pro Smart Dock SD25 - docking station | In Stock | £206.78 |
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - 2 years - 2nd/3rd year - on-site | In Stock | £60.54 |
Dell 1Y BASIC ONSITE TO 3Y PROSPT | In Stock | £153.31 |
Other bundles (29)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £8.69 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £12.80 |
Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black | In Stock | £23.31 |
Dell KB-813 Smart Card Reader | In Stock | £45.62 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.22 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £44.32 |
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £28.14 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £57.37 |
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £35.11 |
Dell WEBCAM - WB3023 | In Stock | £47.02 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £15.38 |
Dell Dell Speakerphone SP3022 | In Stock | £61.06 |
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £157.90 |
Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor | In Stock | £341.58 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £88.69 |
Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £165.88 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £139.87 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £112.94 |
Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £135.97 |
Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £209.52 |
Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor | In Stock | £275.21 |
Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £487.37 |
Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £186.11 |
Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £247.13 |
Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £87.77 |
