Experience powerful performance with the Dell Pro 14 PC14250. Featuring a vibrant 14-inch Full HD Plus display, it offers stunning visuals with a resolution of 1920 x 1200 and anti-glare technology. The IPS panel ensures wide viewing angles, making it suitable for collaboration or presentation purposes. The Intel Core processor and 16 GB of DDR5 RAM, coupled with a quick 256 GB SSD, provide speedy performance to handle multiple tasks. The system comes with ExpressCharge technology to improve battery efficiency, allowing for prolonged use without frequent charging.
Stay connected with advanced connectivity options including USB-C, Thunderbolt, and HDMI ports. The built-in dual-array microphone and high-definition audio ensure clear communication during video calls, while the high-quality webcam features face recognition for added security and convenience. Connectivity options support Wi-Fi 6E for high-speed Internet access, integrating into any workspace. With its robust build and reliable performance, the Dell Pro 14 PC14250 is designed to meet the demands of professionals on the go.
- Dell Pro 14 PC14250 - AI PC - 14" - Intel Core 5 - 120U - 8 GB RAM - 512 GB SSD
- Product Type
- Notebook - AI PC
- Operating System
- Win 11 Pro
- Processor
- Intel Core 5 (Series 1) - 120U / 1.4 GHz, up to 5 GHz / 12 MB Cache
- Memory
- 8 GB DDR5 (1 x 8 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 14" 1920 x 1200 / Full HD Plus @ 60 Hz - 162 ppi
- Graphics
- Intel Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
- Battery
- 3-cell
- Security
- Discrete Trusted Platform Module (TPM 2.0) Security Chip
- Magnetite
- 31.37 cm x 22.53 cm x 2.037 cm
- 1.36 kg
- Pricing Type
- Build To Stock (BTS)
- Manufacturer Selling Program
- Dell Smart Selection
- Environmental Standards
- EPEAT Gold
- Carbon Footprint
- 107 kg carbon emissions
- Bundled Services
- 1 Year Basic Onsite
- Product Type
- Notebook
- AI Level
- AI PC
- Operating System
- Windows 11 Pro
Processor / Chipset
- CPU
- Intel Core 5 (Series 1) 120U / 1.4 GHz
- Max Turbo Speed
- 5 GHz
- Number of Cores
- 10-core
- Performance Cores
- 2
- Efficient Cores
- 8
- Cache
- 12 MB
- 12 Threads
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR5 SDRAM
- Speed
- 5200 MT/s
- Rated Speed
- 5200 MT/s
- Form Factor
- SO-DIMM 262-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
- 14" - IPS
- Resolution
- 1920 x 1200 (Full HD Plus)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 162
- Image Aspect Ratio
- 16:10
- Image Brightness
- 300 cd/m²
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +85 / -85
- Colour Gamut
- 45% NTSC
- Anti-glare, 35 ms response rate, 0.1571 mm pixel pitch
Audio & Video
- Graphics Processor
- Intel Graphics
- Camera
- Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
- Resolution
- 2.07 Megapixel (standard), 0.23 Megapixel (infrared)
- Image Sensor Type
- CMOS
- Video Resolutions
- 1920 x 1080
- Frame Rate
- 30 frames per second
- Camera Features
- Face recognition, IR camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), 80.2 degrees, camera shutter
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio, Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Copilot key
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 211 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111H-CG
- Dual stream (2x2)
- Technology
- 3-cell
- 210 g
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 100-240 V (50/60 Hz)
- Output
- 65 watt, 5/9/15/20 V
Connections & Expansion
- Interfaces Details
- HDMI , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 , USB 3.2 Gen 1 (PowerShare) , LAN (RJ-45) , Headphone/microphone combo jack
Software
- Software Included
- Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
- Magnetite
- Surface Finish
- Texture
- Security
- Intel Rapid Storage Technology, ExpressCharge, ExpressChargeBoost
- Theft/Intrusion Protection
- Security Slot Type
- Wedge-shaped security slot
- Included Accessories
- USB-C power adapter, POD Label
- FIPS 140-2, TCG Certified
- Pricing Type
- 1.36 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- Carbon Footprint
- Manufacturing (kg CO2e)
- 74.15
- Logistics (kg CO2e)
- 4.49
- Use (kg CO2e)
- 26.43
- EOL (kg CO2e)
- 1.93
- Total Carbon w/o Use Phase (kg CO2e)
- 81
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 90% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
Dell Pro Dock WD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE | In Stock | £148.54 |
Dell Pro Smart Dock SD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE | In Stock | £169.95 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - 2 years - 2nd/3rd year - on-site | In Stock | £47.80 |
Other bundles (25)
Dell Slim DW316 USB External DVD Drive | In Stock | £36.19 |
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £7.34 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £11.98 |
Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black | In Stock | £23.24 |
Dell KB-813 Smart Card Reader | In Stock | £43.05 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £26.32 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £36.16 |
Dell SB521A Magnetic Sound bar | In Stock | £28.80 |
Dell MS5120W Mobile Pro Wireless Mouse | In Stock | £25.08 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £59.98 |
Dell Dual Monitor Stand - MDS19 | In Stock | £124.85 |
Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot | In Stock | £43.95 |
Dell WEBCAM - WB3023 | In Stock | £41.59 |
Dell Dell Mobile Wireless Mouse - MS3320W - Black | In Stock | £19.44 |
Dell Dell Speakerphone SP3022 | In Stock | £51.33 |
Dell UltraSharp 24" 1920 x 1080 5 ms IPS | In Stock | £175.52 |
Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor | In Stock | £93.61 |
Dell UltraSharp U2724D - LED monitor - QHD - 27" | In Stock | £278.61 |
Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £103.76 |
Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £209.52 |
Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £466.40 |
Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £256.26 |
Dell SE2225HM 2" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £65.02 |
Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor | In Stock | £78.96 |
Dell UltraSharp U2724DE 27" 2560x1440 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor | In Stock | £328.82 |
