Dell Primary Battery Li-Ion 6-cell 60 Wh/Hr
Quicklinx: BDDQWS00 Mfr#: 451-11977
Power up your system for business trips and vacations with this 6-Cell Battery from Dell™. With a capacity of 60 WHr this battery lets you work seamlessly when you are on the move. The integrated battery charge gauge lets you check the charge status of an installed or uninstalled battery at any time. This product has been tested and validated on Dell systems to ensure it will work with your computer. It is supported by Dell Technical Support when used with a Dell system.
Highlights:
  • Provides 60 WHr capacity
  • Reliable power means dependable performance
Dell Primary Battery - laptop battery - 60 Wh
Laptop battery
6-cell - 60 Wh
Batteries Qty
1
Latitude E5420, E5420m, E5430, E5520, E5520m, E5530, E6420, E6420 ATG, E6430, E6430 ATG, E6440, E6520, E6530, E6540
Laptop battery
Quantity
1
6-cell
60 Wh
Dell Latitude E5420, E5420m, E5430, E5520, E5520m, E5530, E6420, E6420 ATG, E6430, E6430 ATG, E6440, E6520, E6530, E6540
