Lithium-ion batteries are longer lived than conventional batteries and do not require replacement as often. This 6-cell Lithium-ion battery from Dell helps you power up your system for business trips and vacations. With a capacity of 56 WHr this battery lets you work seamlessly when you are on the move.
- Dell Primary Battery - laptop battery - Li-Ion - 56 Wh
- Laptop battery
- Battery
- Lithium Ion 6-cell - 56 Wh
- Designed For
- Vostro 3500, 3700
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Capacity
- 56 Wh
- Designed For
- Dell Vostro 3500, 3700
