The Dell Premium Active Pen features flexible, multi-protocol compatibility with all Dell 2-in-1s with a Windows Ink compatible display. The pen's multi-mode controller can be used across all protocol platforms.
  • Customizable buttons enhance productivity
    Quickly launch OneNote by clicking the top button and write notes (even on a locked screen), capture a screenshot, or activate Cortana. Efficiently erase or launch the context menu with the side buttons. Install Windows Ink Workspace to customize buttons to your needs.
  • Multi-protocol AES 2.0 for a natural writing and drawing experience
    The Dell Premium Active Pen is an active pen that offers multi-protocol compatibility including AES 2.0. Create strokes of varying lightness or darkness, with low lag, and detailed shading thanks to AES 2.0's 4096 levels of pressure sensitivity, 240Hz report rate and tilt support on Dell 2-in-1 notebooks with Wacom AES 2.0 technology. Rest your palm comfortably on the screen when you work and you'll be safe from potential errors thanks to palm rejection technology.
  • Convenient and secure access
    The magnetic pen securely attaches to the side of your 2-in-1 on supported Dell 2-in-1 notebooks, or you can use the included pen lanyard to tether it to your 2-in-1 on supported Dell 2-in-1 notebooks.
Dell Premium Active Pen (PN579X) - active stylus - Bluetooth 4.2, Microsoft Pen Protocol - black
Active stylus
1.02 cm 15 cm
19.6 g
Buttons Qty
3
White LED indicator, Wacom Active ES technology, Wacom Active ES technology (AES) 2.0, Microsoft Pen Protocol (MPP) 1.51, Windows Ink Workspace
AAAA type
Windows 10
1-year warranty
Dell Inspiron 5582 2-in-1, 7579 2-in-1, 5482 2-in-1, 5485 2-in-1, 5490 2-in-1, 5491 2-in-1, 5591 2-in-1, 7386 2-in-1, 7586 2-in-1; Latitude 3390 2-in-1, 5285 2-in-1, 5289 2-In-1, 5300 2-in-1, 5310 2-in-1, 5320 2-in-1, 5420 2-in-1, 7200 2-in-1, 7210 2-in-1, 7285 2-in-1, 7310 2-in-1, 7320, 7320 2-in-1
Active stylus
1.02 cm
15 cm
19.6 g
Input Device
Buttons Qty
3
AAAA battery, replaceable nib, tweezer, tether lanyard
AAAA type
Run Time (Up To)
12 months
Windows 10
Limited warranty - 1 year
Inspiron 5482 2-in-1 , Inspiron 5490 2-in-1 , Inspiron 5491 2-in-1 , Inspiron 5582 2-in-1 , Inspiron 5591 2-in-1 , Inspiron 7586 2-in-1 , Inspiron 7579 2-in-1 , Inspiron 7386 2-in-1 , Inspiron 5485 2-in-1 , Latitude 5300 2-in-1 Chrome Enterprise* , Latitude 5310 2-in-1 , Latitude 5320 2-in-1 , Latitude 5420 2-in-1 , Latitude 7210 2-in-1 , Latitude 7310 2-in-1 , Latitude 7320 2-in-1 , Latitude 7320 Detachable** , Latitude 7410 2-in-1 , Latitude 7410 2-in-1 Chrome Enterprise* , Latitude 7420 2-in-1 , Latitude 9410 2-in-1 , Latitude 9420 2-in-1 , Latitude 9520 2-in-1 , Latitude 9510 2-in-1 , Latitude 7389 2-in-1 , Latitude 7285 2-in-1 , Latitude 5289 2-in-1 , Latitude 5285 2-in-1 , Latitude 3390 2-in-1# , Latitude 5300 2-in-1 , Latitude 7200 2-in-1 , Latitude 7400 2-in-1 , Precision 5530 2-in-1 , XPS 13 7390 2-in-1 , XPS 13 9310 2-in-1 , XPS 15 (9575) 2-in-1 , , * Chrome OS does not support Bluetooth pairing with Dell active pens. , ** Recommended pen for this system is the Dell Latitude 7320 detachable Active Pen – PN7320A. , # Only select configurations with pen-enabled displays offer active pen support.
