Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse
Quicklinx: GQR1WS00 Mfr#: KM7321WGY-UK
Recommended Use: Leisure
Type: Mouse, Keyboard
Wired / Wireless: Wireless
Colour: Titan grey
Compatibility: Android, PC, Mac
More than 50 In Stock
£59.12 ex VAT
£70.94 inc VAT
Dell Premier Multi-Device Wireless Keyboard and Mouse - KM7321W - UK (QWERTY).
  • Flexible multi-tasking
    Seamlessly connect up to three devices with this premium keyboard and mouse combo. The dual mode RF 2.4 GHz and Bluetooth 5.0 connectivity lets you effortlessly switch across devices with the connection-mode key or button on your keyboard and mouse.
  • Navigate with precision
    Easily maneuver across monitors of varying resolutions at home or in the office. Dell Peripheral Manager (DPM) software enables you to manage your input devices and adjust to your preferred preset DPIs at 1000, 1600, 2400 or 4000.
  • Customize your way
    Gain instant access to your frequently used applications or functions with 12 programmable keys on your keyboard and 5 programmable mouse buttons. Power through your work with a full-sized keyboard that comes with a dedicated numeric pad, function keys, and programmed presets. Download the DPM software and easily pair your devices, adjust DPI on your mouse, check battery and connectivity status, program shortcuts and update to the latest firmware.
  • Well-crafted design
    The thoughtfully designed quiet keyboard is slim and stylish with a premium feel and titan gray finish. Experience all day comfort thanks to the sculpted mouse that fits perfectly in your hand. The adjustable tilt legs on your keyboard give you the flexibility to work in your ideal typing position.
  • Durable and secure
    The Dell Premier Multi-Device Wireless Keyboard and Mouse combo has been rigorously tested to work seamlessly with your Dell system. The keyboard offers 128-bit AES (Advanced Encryption Standard) encryption protecting your data transmission across your PCs and devices, providing you with a secure connection while typing.
Dell Premier Multi-Device KM7321W - keyboard and mouse set - QWERTY - UK - titan grey Input Device
Keyboard and mouse set
2.4 GHz, Bluetooth 5.0
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
QWERTY UK
Hot Keys Function
Volume, mute
Pointing Device
Mouse - wireless - optical
Buttons Qty
7
Titan grey
Bundled Services
3 years NBD Advance Exchange
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 43.33 cm x 12.15 cm x 2.836 cm / 561 g , Mouse: 6.97 cm x 11.45 cm x 4.16 cm / 84 g
Bundled Services
Wireless
Hot Keys Function
Volume, mute
QWERTY UK
Keyboard Technology
Scissors
Pointing Device
Mouse - wireless
Buttons Qty
7
Movement Detection Technology
Optical
Movement Resolution
4000 dpi
Batteries:
1
Supported Battery Type
AA x 1
Titan grey
AA battery, 2 AAA batteries
AES-128
Included Software
Dell Peripheral Manager (Windows only)
Apple MacOS, Android, Google Chrome OS, Microsoft Windows 7 / 8.1 / 10, Red Hat Enterprise Linux 8.0, Ubuntu 18.04
Type: Mouse
Type: Keyboard
Colour: Titan grey
Compatibility: PC
Compatibility: Mac
Brand: Dell
