Dell Precision T5810 Intel Xeon E5-1620 v3 16GB 1TB Win 7 Pro
Quicklinx: BZVWWS00 Mfr#: P7CMD
  • Xeon
  • Microsoft Windows 7 Professional 64-bit Edition
Tower workstation in a compact design with expansion options. A new generation of performance.
Choose the Dell actively cooled PCIe SSD storage solution for the fastest and most reliable way to store your content, up to 180% faster than traditional SATA SSD storage.
Reduce the time spent loading or saving large data sets with software- or hardware-based RAID controllers for your hard drive, available on all Precision Workstations.
Quick Resource Locator (QRL): Model-specific QR codes located on the system allow you to quickly access detailed how-tos and troubleshoot hardware from your smartphone.
  • Powerful processors
    Power through the most demanding, interactive applications quickly with incredible performance with processor series. The Dell Precision Tower 5810 delivers better performance for iterative design and prototyping.
  • Powerful graphics and memory
    The superb graphics deliver the muscle you need to run the most demanding software applications. Impressive graphics offer larger dedicated graphics memory for your large data sets. System memory is expandable using the latest DDR4 RDIMM memory technology.
  • Certified for seamless reliability
    ISV (Independent Software Vendor) certification means that the Dell Precision Workstations you purchase are tested to ensure the high-performance applications you rely on every day run smoothly. ISV certification is the result of precise engineering and rigorous testing to optimize performance and reliability to run leading industry applications for engineering, manufacturing, media, entertainment, healthcare, life sciences, oil, gas, economics and financial services.
  • Improve productivity with Dell Precision Optimizer 2.0
    Different applications have different system requirements. Let Dell Precision Optimizer 2.0 take the guesswork out of customizing settings by automatically adjusting Intel Hyper-Threading, number of CPU cores, graphics and power settings. Free with your Dell Precision, the Dell Precision Optimizer 2.0 automatically tunes your Workstation to run specific programs at the fastest speeds possible, enhancing productivity. The engineers have created profiles specifically for the applications you use, minimizing the need to customize settings according to each application.
  • Maximize reliability with Reliable Memory Technology (RMT)
    Dell's exclusive, patented Reliable Memory Technology (RMT) helps maximize uptime and ensure that your Workstations work as hard as you do. RMT works in conjunction with error-correcting code (ECC) memory to detect and correct memory errors in real time. RMT makes memory errors virtually nonexistent so that the bad memory is never revisited again and the DIMM can still be used. With a simple system reboot, RMT isolates the defective area in memory and hides it from the OS.
  • Customizable management
    Update once and update everywhere with Dell-unique Intel vPro extensions for remote BIOS management and hard drive wipe, even when systems are offline.
  • Dell Client Command Suite
    By building unique management capabilities into Dell Precision Workstations, Dell Client Command Suite provides free automation tools that help automate and streamline system deployment, monitoring and updating in complex IT environments.
  • Seamless integration
    Automation tools work with all management consoles and integrate seamlessly with Microsoft Systems Center 2012, allowing fewer steps to import drivers.
  • Security and performance
    Dell Precision Workstations feature best-in-class endpoint security solutions that include comprehensive encryption, advanced authentication and improved malware protection from a single source.
Dell Precision Tower 5810 - mid tower - Xeon E5-1620V3 3.5 GHz - vPro - 16 GB - HDD 1 TB
Workstation - mid tower
Platform Technology
Intel vPro Platform
1 x Intel Xeon E5-1620V3 / 3.5 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
10 MB
Cache Per Processor
10 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
NVIDIA Quadro K2200
Video Memory
4 GB
GigE
OS Provided
Software Included
Microsoft Office (Trial), Windows 7 Professional 64-bit recovery DVD
17.26 cm x 47.1 cm x 41.4 cm
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - response time: next business day
Platform Technology
Intel vPro Platform
Workstation
Product Form Factor
Mid tower
Processor / Chipset
CPU
Clock Speed
3.5 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C612
Cache Memory
Installed Size
10 MB
Cache Per Processor
10 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
8 (Total)
Quad channel memory architecture
Configuration Features
2 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro K2200
Video Memory
4 GB
Audio Output
High Definition Audio
Input Device
Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
Optical
USB
Ethernet Controller
Intel I217
Remote Wake Up, PXE support
Bays
2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 external 5.25" x 1/2H , 1 external 5.25" Slim Line
Slots
1 (total) / 0 (free) x CPU , 8 (total) / 6 (free) x DIMM 288-pin , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length (x8 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length , 1 (total) / 1 (free) x PCI - full-length
6 x USB 2.0 (3 front, 3 rear) , 4 x USB 3.0 (1 front, 3 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x LAN (Gigabit Ethernet)
GS, CECP
Pricing Type
Build To Plan (BTP)
Power supply
80 PLUS Certification
80 PLUS Gold
Efficiency
90%
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
17.26 cm
47.1 cm
41.4 cm
BZVW C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
BZVW C2G 12m USB 2.0 A/A Active Extension Cable In Stock £18.89
