Dell Precision 5760 i7 11850H 32GB 512GB 17" Win10P
Quicklinx: GSRYWS00 Mfr#: 5GPTF
  • Core i7
  • IEEE 802.11n
UK/BTP/Preci 5760/Core i7-11850H/32GB/512GB SSD/17.0" UHD+ Touch/NVIDIA RTX A3000/FgrPr/Cam & Mic/WLAN + BT/Backlit Kb/6 Cell/W10Pro/vPro/3Y Basic Onsite.
Dell Precision 5760 - 17" - Intel Core i7 - 11850H - vPro - 32 GB RAM - 512 GB SSD
Mobile workstation
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i7 (11th Gen) - 11850H / 2.5 GHz, up to 4.8 GHz / 24 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
512 GB SSD - NVMe
Display
17" touchscreen 3840 x 2400 / WQUXGA @ 60 Hz - 266 ppi
Graphics
NVIDIA RTX A3000
Video Memory
6 GB GDDR6 SDRAM
Input Device
Keyboard, touchpad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.2
6-cell
Security
Fingerprint reader
Grey
37.448 cm x 24.808 cm x 1.315 cm
2.13 kg
Pricing Type
Build To Plan (BTP)
Bundled Services
3 Years Basic Onsite
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i7 (11th Gen) 11850H / 2.5 GHz
Max Turbo Speed
4.8 GHz
Number of Cores
8-core
Cache
24 MB
Chipset
Intel WM590
Platform Technology
Intel vPro Platform
Intel Smart Cache
RAM
32 GB (2 x 16 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
3200 MHz
Rated Speed
3200 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
17"
Touchscreen
Resolution
3840 x 2400 (WQUXGA)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
266
Image Aspect Ratio
16:10
Image Brightness
500 cd/m²
Colour Gamut
99% DCI-P3, 100% Adobe RGB
Anti-reflective, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.0954 mm pixel pitch
Audio & Video
Graphics Processor
NVIDIA RTX A3000
Video Memory
6 GB GDDR6 SDRAM
Camera
Yes - 1280 x 720 (standard), 576 x 360 (infrared)
Resolution
0.92 Megapixel (standard), 0.2 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
IR camera, Windows Hello, RGB camera, 78.5 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC711-CG
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
6-cell Lithium Ion
97 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
130 Watt, 5 / 20 V
Connections & Expansion
Interfaces Details
4 x USB-C (supports Thunderbolt 4) (DC-In combo) , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office (Trial)
Grey
Security
Fingerprint reader
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter, USB-C to HDMI/USB Type A adapter
Pricing Type
Build To Plan (BTP)
2.13 kg
Sustainability Information
TCO Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
GSRY Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £171.38
Other bundles (10)
GSRY Dell Slim DW316 USB External DVD Drive In Stock £35.33
GSRY Dell KB-813 Smart Card Reader In Stock £32.19
GSRY Dell Ultrasharp U2421E 23.8" 1920x1200 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £209.52
GSRY Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.73
GSRY Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £47.93
GSRY Dell SB521A Magnetic Sound bar In Stock £36.88
GSRY Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.00
GSRY Dell UltraSharp U3223QE 31.5" 3840x2160 8ms DisplayPort HDMI USB-C IPS LED Monitor In Stock £650.57
GSRY Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GSRY Dell Dual Monitor Stand - MDS19 In Stock £166.38
