Dell Precision 3571 Intel Core i7-12700H 16GB 512GB 15.6" Windows 10 Professional 64-bit
Quicklinx: GWQZWS00 Mfr#: FMG5G
  • Core i7
  • IEEE 802.11n
Precision 3571|i7-12700H|16GB|512GB SSD|15.6" FHD|IR Cam & Mic|Nvidia T600|SmtCd|4 cell|PSU|WLAN|vPro|Backlit Kb|W10Pro+W11Pro Licence|3Y Basic Onsite.
  • Mobile design
    The thin and light design overall starts at a light weight.
  • Captivating and comfortable display
    With a bright 400 nit, Full HD display, up to 100% sRGB
  • Long battery life
    Get a 4-Cell 64 WHr with standard and long lifecycle.
  • Advanced thermals
    With a larger Dual Opposing Output (DOO) fan and dual heat pipes help the workstation run quietly and at higher speeds for longer vs previous generations.
  • Express connect
    Automatically connects you to the best network and delivers unmatched connectivity with the world's first simultaneous multi-network connection.
Dell Precision 3571 - 15.6" - Intel Core i7 - 12700H - vPro Essentials - 16 GB RAM - 512 GB SSD
Mobile workstation
Operating System
Win 10 Pro 64-bit + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Platform Technology
Intel vPro Essentials
Intel Core i7 (12th Gen) - 12700H / 2.3 GHz, up to 4.7 GHz / 24 MB Cache
16 GB DDR5 (1 x 16 GB)
Storage
512 GB SSD - NVMe, Class 40
Display
15.6" 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
Graphics
NVIDIA T600
Video Memory
4 GB GDDR6 SDRAM
Input Device
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Integrated Webcam
Bluetooth, 802.11a/b/g/n/ac/ax (Wi-Fi 6E), Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
Grey
35.78 cm x 23.33 cm x 2.405 cm
1.79 kg
Bundled Services
3 Years Basic Onsite
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition + Windows 11 Pro Licence - Dutch / English / French / German / Italian
Processor / Chipset
CPU
Intel Core i7 (12th Gen) 12700H / 2.3 GHz
Max Turbo Speed
4.7 GHz
Number of Cores
14-core
Cache
24 MB
Chipset
Intel H45
Platform Technology
Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
64 GB
DDR5 SDRAM
Speed
4800 MHz
Rated Speed
4800 MHz
SO-DIMM 262-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe 4.0 x4 - NVM Express (NVMe), Class 40
Display
15.6"
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
141
Image Aspect Ratio
16:9
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Anti-glare, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle, 35 ms response rate, 0.179 mm pixel pitch, Low Blue Light technology, Super Low Power Panel (SLP)
Audio & Video
Graphics Processor
NVIDIA T600
Video Memory
4 GB GDDR6 SDRAM
Camera
Yes - 1920 x 1080 (standard), 640 x 360 (infrared)
Resolution
2.07 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
1920 x 1080
Frame Rate
30 frames per second
Camera Features
Privacy shutter, IR camera, RGB camera, Temporal Noise Reduction
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6E AX 211 - M.2 2230
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Dual stream (2x2)
4-cell lithium polymer
64 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
130 Watt, 5 / 20 V, 6.5 A
Connections & Expansion
Interfaces Details
HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , LAN (RJ-45) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (30 days trial, excludes office licence)
Grey
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
FIPS 140-2
1.79 kg
Sustainability Information
TCO Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
GWQZ Dell Slim DW316 USB External DVD Drive In Stock £39.99
GWQZ Dell KB-813 Smart Card Reader In Stock £38.69
GWQZ Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
GWQZ Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £45.03
GWQZ Dell SB521A Magnetic Sound bar In Stock £35.11
GWQZ Dell MS5120W Mobile Pro Wireless Mouse In Stock £25.91
GWQZ Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.19
GWQZ Dell Dual Monitor Stand - MDS19 In Stock £174.65
