Dell Precision 3530 i7-8850H 16GB 500GB SSD 15" Win 10 Pro
Quicklinx: F2H4WS00 Mfr#: G8DJD
  • Core i7
  • IEEE 802.11n
Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
  • Small design, big performance
    This small mobile workstation packs a powerful punch, with an enhanced design to bring your greatest ideas to life.
  • Robust graphics
    Master any visualization challenge in no time with next generation NIVIDIA Quadro professional graphics cards.
  • Fit for your lifestyle
    Designed with cable docking, this small and compact workstation can carry large projects wherever the job takes you.
  • Connect with ease
    Support for 4K video to an external monitor at 60 frames per second via HDMI 2.0 allows you to create and edit your work in perfect clarity.
Dell Precision 3530 - 15.6" - Intel Core i7 - 8850H - vPro - 16 GB RAM - 512 GB SSD
Mobile workstation
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i7 (8th Gen) - 8850H / 2.6 GHz, up to 4.3 GHz / 9 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
512 GB SSD - NVMe
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P600
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
37.6 cm x 25.07 cm x 2.43 cm
2.03 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i7 (8th Gen) 8850H / 2.6 GHz
Max Turbo Speed
4.3 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Platform Technology
Intel vPro Platform
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Anti-glare, PremierColor technology, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle
Audio & Video
Graphics Processor
NVIDIA Quadro P600
Video Memory
4 GB GDDR5 SDRAM
Camera
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
74 degrees
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3246-CG
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Precision touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
Wake-on-LAN (WOL)
4-cell
68 Wh
AC Adapter
Input
Output
130 Watt, 19.5 V, 6.67 A
Connections & Expansion
Interfaces Details
USB-C (supports Thunderbolt 3, DisplayPort Alt Mode) , LAN , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , VGA , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, Memory Stick, MultiMediaCard, Memory Stick PRO-HG Duo, SDHC Card, SDXC Card, Memory Stick XC, SDXC UHS-II Card, SDXC UHS Card, Memory Stick PRO-HG)
Security
Microphone with noise-cancellation
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
Build To Plan (BTP)
2.03 kg
Sustainability Information
TCO Certified
Get more from your purchase from one of our essential accessories
F2H4 Dicota Privacy filter 2-Way for Laptop 15.6" Wide (16:9), side-mounted In Stock £37.53
