The PowerEdge T640 is a versatile, powerhouse server ideal for mid-sized offices, remote sites and data centers. The T640 combines powerful performance and massive internal storage capacity in a rack or tower platform. Address a wide range of workloads and future-proof your data center with flexible storage, performance and I/O options.
Meet evolving business needs with the scalable business architecture of the PowerEdge T640. Accelerate demanding workloads and plan for future growth with cost-effective, in-server expansion.
Dell OpenManage intelligent automation enables you to spend less time on routine maintenance so you can focus on business-critical priorities.
A comprehensive, cyber-resilient architecture with security embedded into every server helps to protect your data.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge T640 - tower - Xeon Silver 4110 2.1 GHz - 16 GB - SSD 240 GB - with 3-year ProSupport
- Server - tower
- Bundled Services
- 3 Years ProSupport
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SAS 12Gb/s) (Dell PERC H730P+)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- SSD 240 GB (hot-swap) - 2.5"
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eW3
- Video Memory
- 16 MB
- Networking
- GigE, 10 GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 30.45 cm x 70.78 cm x 47.15 cm
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years
- Server
- Bundled Services
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- 2-way
- Hot-Swap Bays Qty
- 16
- Black
Processor / Chipset
- CPU
- Intel Xeon Silver 4110
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- 16 GB / 768 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 3072 GB Load-Reduced - ECC , 768 GB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- SSD - hot-swap - 2.5"
- Capacity
- 1 x 240 GB
Storage Controller
- 1 x RAID
- Controller Interface Type
- SAS 12Gb/s
- Storage Controller Name
- Dell PERC H730P+
- Buffer Size
- 2 GB
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eW3
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- LAN-on-motherboard (LOM)
- Ethernet Ports
- 2 x 10 Gigabit Ethernet
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 16 (total) / 15 (free) x hot-swap 2.5"
- Slots
- 2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 PCIe 3.0 x8 - half-length, full-height (2 processors must be installed) , 1 PCIe 3.0 x8 - full-length, full-height (2 processors must be installed) , 2 PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 PCIe 3.0 x8 - full-length, full-height (x4 mode, 2 processors must be installed)
- 3 x USB 2.0 (1 front, 2 rear) , 5 x USB 3.0 (1 front, 4 rear) , 1 x management , 1 x VGA , 2 x LAN (10Gigabit Ethernet)
- Included Accessories
- Bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 30.45 cm
- 70.78 cm
- 47.15 cm
- 10 °C
- 35 °C
- 10 - 80%
Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase | In Stock | £157.30 |
