Dell PowerEdge T630,Intel Xeon E5-2603v4,4GB RAM,1 TB SATA,No OS
Quicklinx: CN7TWS00 Mfr#: T630-0817
  • Xeon
Drive a wide range of demanding workloads with a flexible server offering peak 2-socket performance and huge internal storage capacity.
Accelerate demanding workloads with the powerful and flexible PowerEdge T630 2-socket tower server, a member of the 13th generation of PowerEdge servers.
Expanded capacity, unprecedented capability: With support for up to 50 percent more hard drives than previous generations, the PowerEdge T630 brings new capabilities to small and medium businesses and remote offices running mail and messaging, medical imaging, server and desktop virtualization, and budget-conscious graphical rendering. Supporting up to 32 x 2.5" or 18 x 3.5" hard drives, the T630 can store more mailboxes of larger sizes can dramatically lower your cost per mailbox. Flexible storage configurations allow you to meet exacting workload requirements, while ample drive space allows for cost-effective, in-server expansion.
Manage your servers the way you want: individually, collectively, in-person, remotely or with your smartphone - it's your choice. Consistent administration and 3rd-party integration ensures seamless management of PowerEdge servers.
Administer systems from your smartphone, laptop or at the system with both local and remote management options.
Whether installed as a tower or rack-mounted server, the PowerEdge T630 is ready to drive your demanding workloads today and into the future. With its powerful and scalable performance, Fresh Air 2.0 compliance and library-quiet acoustics, it has the versatility to accelerate a wide range of demanding workloads.
  • Versatile and efficient performance
    Drive rapid response times with the powerful processor E5-2600 v3 product family, DDR4 memory and seven I/O slots.
  • Expanded capacity, unprecedented capability
  • Fast storage, fast insights
    Up to four NVMe Express Flash PCIe SSDs and the optional 12Gb PowerEdge RAID Controller (PERC9) make the PowerEdge T630 ideal for a wide range of IOPs-hungry workloads including database, enterprise resource planning (ERP) and decision support. For increased application acceleration, the T630 can take advantage of optional Dell Fluid Cache for SAN and SanDisk DAS Cache for even faster data access. In-server storage tiering and multi-mode RAID options also help optimize virtual storage for VMware vSAN and Microsoft Storage Spaces.
  • Powerful GPU acceleration
    From graphical rendering to implementing virtual desktops, support for up to four optional GPU accelerators enables additional performance and capability.
Dell PowerEdge T630 - tower Xeon E5-2603V4 1.7 GHz - 4 GB - HDD 1 TB
Server - tower
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon E5-2603V4 / 1.7 GHz (6-core)
Cache Memory
15 MB
Cache Per Processor
15 MB
RAM
4 GB (installed) / 768 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s) (Dell PERC S130)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
HDD 1 TB (hot-swap) - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Matrox G200
Video Memory
16 MB
1GbE
OS Provided
No operating system
30.45 cm x 70.87 cm x 44.35 cm
Pricing Type
BTO
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Tower - 5U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
1.7 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C612
Cache Memory
Installed Size
15 MB
Cache Per Processor
15 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2400 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, single rank
Configuration Features
1 x 4 GB
Hard Drive
HDD - hot-swap
1 x 1 TB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Dell PERC S130
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 8 Express (iDRAC8)
Bays
8 (total) / 7 (free) x hot-swap 3.5"
Slots
2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 2.0 x4 - full-length, full-height , 1 PCIe 3.0 x8 - half-length, full-height , 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin
4 x USB 2.0 , 3 x USB 3.0 (1 front, 2 rear) , 2 x VGA (1 front, 1 rear) , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
Pricing Type
BTO
Power supply
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
30.45 cm
70.87 cm
44.35 cm
10 °C
35 °C
10 - 80%
