The PowerEdge T440 tower server delivers powerful 2-socket performance, expandability and quiet operation to your small to mid-sized business (SMB) and remote office/branch office (ROBO) sites. Outstanding efficiency helps you keep operating expenses in check as your requirements evolve.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge T440 - tower - Xeon Bronze 3106 1.7 GHz - 8 GB - SSD 240 GB
- Server - tower
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Bronze 3106 / 1.7 GHz (8-core)
- Cache Memory
- 11 MB
- Cache Per Processor
- 11 MB
- RAM
- 8 GB DDR4 SDRAM
- Storage Controller
- RAID (SAS 12Gb/s) (Dell PERC H330+)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- SSD 240 GB (hot-swap)
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 21.8 cm x 57.3636 cm x 47.1333 cm
- 29.5 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- 2-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon Bronze 3106
- Clock Speed
- 1.7 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 11 MB
- 11 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2667 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, single rank
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - hot-swap
- Capacity
- 1 x 240 GB
Storage Controller
- 1 x RAID
- Controller Interface Type
- SAS 12Gb/s
- Storage Controller Name
- Dell PERC H330+
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- LAN-on-motherboard (LOM)
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 8 (total) / 7 (free) x hot-swap 3.5"
- Slots
- 2 PCIe 3.0 x4 - half-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height , 2 PCIe 3.0 x8 - half-length, full-height
- 5 x USB 2.0 - Type A (1 front, 4 rear) , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 1 x VGA (1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear)
- Included Accessories
- Bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 21.8 cm
- 57.3636 cm
- 47.1333 cm
- 29.5 kg
- 10 °C
- 35 °C
- 10 - 80%
Dell SFP+ Transceiver Module 10 Gigabit Ethernet - 10GBase | In Stock | £188.20 |
