The PowerEdge T430 tower server delivers powerful 2-socket performance, expandability and quiet operation to small businesses and organizations. Save time and reduce potential for error with simplified, intuitive systems management, and help reduce costs with energy-efficient features. A highly flexible design lets you deploy server performance where it's needed and adapt as your requirements change over time. The T430 is an ideal choice for a wide range of office workloads, such as 1. Workgroup collaboration and productivity; 2. Mail and messaging; 3. File and print serving; 4. Web serving.
Powerful, expandable and quiet
The PowerEdge T430 tower server delivers powerful 2-socket performance, expandability and quiet operation to small businesses and organizations. -
Deliver peak performance
Accelerate your applications with the latest Intel Xeon processor and boost memory and I/O performance. -
Scale and adapt with greater versatility
A highly flexible design lets you deploy server performance where it's needed and adapt as your requirements change over time. -
Maximize operational efficiency
- Dell PowerEdge T430 - tower - Xeon E5-2620V4 2.1 GHz - 16 GB - HDD 2 x 300 GB
- Server - tower
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 20 MB
- Cache Per Processor
- 20 MB
- RAM
- 16 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- 2 x HDD 300 GB (hot-swap) - SAS - 10000 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 100 - 240 V (50/60 Hz)
- Power Redundancy
- OS Provided
- No operating system
- Black
- 30.45 cm x 54.22 cm x 44.33 cm
- 30.16 kg
- Pricing Type
- BTO
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- 2-way
- Front Accessible Bays Qty
- 3
- Hot-Swap Bays Qty
- 16
- Black
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 20 MB
- 20 MB
RAM
- Installed Size
- 16 GB / 384 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 12 (Total) / 11 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 16 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 300 GB
- Interface Type
- SAS
- Spindle Speed
- 10000 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Dell PERC H730
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
- 1 GB
Optical Storage
- DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Protocol
- IPMI 2.0
- Remote Management Controller
- Integrated Dell Remote Access Controller 8 Express (iDRAC8)
- Bays
- 16 (total) / 14 (free) x hot-swap 2.5" , 3 (total) / 2 (free) x external 5.25"
- Slots
- 1 PCIe 2.0 x4 - half-length, full-height , 1 PCIe 2.0 x1 - half-length, full-height , 2 PCIe 3.0 x16 - full-length, full-height , 2 PCIe 3.0 x8 - half-length, full-height , 2 (total) / 1 (free) x CPU , 12 (total) / 11 (free) x DIMM 288-pin
- 6 x USB 2.0 (1 front, 5 rear) , 2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x serial , 2 x USB 3.0 (1 front, 1 rear)
- Included Accessories
- Bezel
- Pricing Type
- BTO
- Power supply
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 30.45 cm
- 54.22 cm
- 44.33 cm
- 30.16 kg
- 10 °C
- 35 °C
- 10 - 80%
