Develop your business with the PowerEdge T340 tower server. It is a reliable, easy to manage, and scalable one-socket server. The PowerEdge T340 helps you share and connect quickly across your organization to drive business results.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge T340 - tower - Xeon E-2124 3.3 GHz - 8 GB - HDD 1 TB
- Server - tower
- Height (Rack Units)
- 5U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E-2124 / 3.3 GHz (, up to 4.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H330)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- HDD 1 TB (hot-swap) - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 21.8 cm x 60.32 cm x 47.13 cm
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - on-site
- Server
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- 1-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon E-2124
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 4.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- Dell PERC H330
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- LAN-on-motherboard (LOM)
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Express (iDRAC9)
- Bays
- 8 (total) / 7 (free) x hot-swap 3.5"
- Slots
- 2 PCIe 3.0 x8 - half-length, full-height , 1 PCIe 3.0 x16 - half-length, full-height , 1 PCIe 3.0 x1 - half-length, full-height
- 4 x USB 2.0 - Type A , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 2 x VGA (1 front, 1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear) , 1 x management - micro-USB (1 in front)
- Included Accessories
- Bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 495 Watt
Operating System / Software
- OS Provided
- 21.8 cm
- 60.32 cm
- 47.13 cm
- 10 °C
- 35 °C
- 10 - 80%
