Dell PowerEdge R740 Intel Xeon Silver 4214 32GB 240GB SSD
Quicklinx: FL0VWS00 Mfr#: JWPD7
Maximize application performance with the optimal mix of accelerator cards, storage and compute power in a platform optimized for VDI.
  • More processing power
    Powerful processors boost virtualized environments and performance-hungry business applications.
  • High-capacity, low-power memory
    Improved memory accelerates workloads, like enterprise resource planning and database applications.
  • Scalable, efficient local storage
    Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value.
  • Simplified, intelligent management
    Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks.
  • Energy efficiency
    Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
Dell PowerEdge R740 - rack-mountable - Xeon Silver 4214 2.2 GHz - 32 GB - SSD 240 GB
Server - rack-mountable
Bundled Services
3 Years Basic Onsite
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Silver 4214 / 2.2 GHz (, up to 3.2 GHz, (12-core)
Cache Memory
16.5 MB
Cache Per Processor
16.5 MB
RAM
32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (Dell PERC H730P)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
SSD 240 GB (hot-swap)
Optical Storage
No optical drive
Graphics Controller
Matrox G200eW3
Video Memory
16 MB
1GbE
Power Redundancy
OS Provided
No operating system
48.2 cm x 75.134 cm x 8.68 cm
26.3 kg
Pricing Type
Build To Plan (BTP)
Server
Bundled Services
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
16
Processor / Chipset
CPU
Clock Speed
2.2 GHz
Max Turbo Speed
3.2 GHz
Number of Cores
12-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
16.5 MB
Cache Per Processor
16.5 MB
RAM
Installed Size
32 GB / 1.5 TB (max)
DDR4 SDRAM - ECC
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
24 (Total) / 22 (empty)
Registered, dual rank
Configuration Features
2 x 16 GB
RAM Supported
1.5 GB registered - ECC , 3 TB Load-Reduced - ECC , 192 GB Non-Volatile - ECC
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Dell PERC H730P
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eW3
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
16 hot-swap 2.5"
Slots
4 PCIe 3.0 x8
4 x LAN (Gigabit Ethernet) , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A (2 in front) , 1 x USB 2.0 - micro-USB (1 in front) , 1 x management (NIC) , 1 x serial , 2 x VGA (1 front, 1 rear)
Rack sliding rails, bezel, riser card
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
75.134 cm
8.68 cm
26.3 kg
10 °C
35 °C
10 - 80%
