Dell PowerEdge R730 Dual Xeon E5-2650v3 32GB (2x16GB) 300GB SAS
Quicklinx: B845WS00 Mfr#: R730-3514
  • Xeon
Adapt to virtually any workload with a scalable server featuring an optimal mix of memory, storage, processing and GPUs. The incredible versatility of the PowerEdge R730 server delivers outstanding functionality in just 2U of rack space. With the combination of powerful processors, large memory, fast storage options and GPU accelerator support, the R730 performs exceptionally well in a number of demanding environments.
  • Deliver peak performance
    Drive peak compute performance across a variety of workloads with the Intel Xeon processor E5-2600 v4 product family and state-of-the-art DDR4 memory. Boost data access for applications with 12 Gbps SAS drives and high-performance dual RAID. Take advantage of advanced accelerators and GPUs to maximize performance in HPC, VDI and imaging environments.
  • Discover greater versatility
    With 24 DIMMs of high-capacity, low-power DDR4 memory, seven PCI Express (PCIe) 3.0 expansion slots and highly scalable local storage, the R730 is extremely flexible. Create a dense, resource rich virtualization environment with 2.5" drives. Combine that with the R730's GPU capability to save infrastructure costs and consolidate management operations in a scalable and centralized virtual desktop environment. The GPU option also makes the R730 an excellent choice as a midrange medical imaging solution.
  • Maximize operational efficiency
    PowerEdge servers let you construct and manage highly efficient infrastructures for data centers and small businesses. Accelerate time-to-production with automated deployment processes that use fewer manual steps and reduce the potential for error. Improve IT productivity with innovative at-the-server management tools like iDRAC Direct and iDRAC Quick Sync to deliver in-depth system health status and speed deployment, optimize data center energy usage with improved performance-per-watt and more granular control of power and cooling.
  • Innovative management with intelligent automation
    The Dell OpenManage systems management portfolio includes innovative solutions that simplify and automate essential server lifecycle management tasks - making IT operations more efficient and Dell EMC servers the most productive, reliable and cost effective. Leveraging the incomparable agent-free capabilities of the PowerEdge embedded integrated Dell Remote Access Controller (iDRAC) with Lifecycle Controller technology, server deployment, configuration and updates are streamlined across the OpenManage portfolio and through integration with third-party management solutions.
Dell PowerEdge R730 - rack-mountable - Xeon E5-2650V3 2.3 GHz - 32 GB - HDD 300 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
2 x Intel Xeon E5-2650V3 / 2.3 GHz (, up to 3 GHz, (10-core)
Processor Socket
FCLGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
50 MB
Cache Per Processor
25 MB
RAM
32 GB (installed) / 768 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SAS 12Gb/s) (Dell PERC H730)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
HDD 300 GB (hot-swap)
Optical Storage
No optical drive
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
OS Provided
No operating system
48.2 cm x 75.58 cm x 8.73 cm
18.9 kg
Limited warranty - 3 years - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Server Scalability
2-way
Hot-Swap Bays Qty
16
Processor / Chipset
CPU
Clock Speed
2.3 GHz
Max Turbo Speed
3 GHz
Number of Cores
10-core
CPU Qty
2
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
50 MB
Cache Per Processor
25 MB
RAM
Installed Size
32 GB / 768 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
24 (Total)
Registered
RAM Supported
768 GB registered - ECC , 3 TB Load-Reduced - ECC
Hard Drive
HDD - hot-swap
1 x 300 GB
Storage Controller
1 x RAID - integrated
Controller Interface Type
SAS 12Gb/s
Storage Controller Name
Dell PERC H730
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Integrated
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Dell Remote Access Controller 8 Express (iDRAC8)
Bays
16 (total) / 15 (free) x hot-swap 2.5"
Slots
3 PCIe 3.0 x16 - low-profile (x8 mode) , 2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height (x8 mode)
2 x USB 3.0 , 2 x VGA (1 front, 1 rear) , 1 x USB 2.0 , 1 x serial , 4 x LAN (Gigabit Ethernet)
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
48.2 cm
75.58 cm
8.73 cm
18.9 kg
10 °C
35 °C
10 - 80% (non-condensing)
