With 2U performance packed into a compact 1U chassis, the PowerEdge R630 two-socket rack server delivers uncompromising density and productivity. Part of the 13th generation of PowerEdge servers, the R630 is ideal for virtualization, driving large business applications or running transactional databases.
The processor and memory density as well as storage flexibility of 300 GB HDD provides an ideal solution for large-scale transactional and analytical processing solutions, such as Oracle and SQL.
Manage your data center servers the way you want: individually, collectively, in-person, remotely, or with your smartphone - it's your choice. Consistent administration and 3rd-party integration ensures seamless management of PowerEdge servers.
Deliver peak performance
Build a blazingly fast transactional database with the R630 24 all-flash drive configuration. Combine the density, scalability and performance of 1.8" SSDs with dual-PERC capability to deliver a superior solution that can boost performance by storing an entire database. When combined with the SanDisk DAS Cache solution, the R630 can help increase OLTP transactions and concurrent usage for latency-sensitive applications, such as e-commerce or financial trading. -
Discover greater versatility
With DIMMs of memory, and configured with 2.5" drives, the R630 can provide a dense, resource-rich midsize virtualization environment to drive business intelligence applications, from customer relationship management (CRM) to enterprise resource planning (ERP), while it saves on space, energy and capital costs. -
Maximize operational efficiency
Quickly and securely monitor or modify critical server settings "at the box" with the iDRAC Quick Sync bezel with embedded near field communication (NFC) capability. Use a handheld device with the bezel to quickly check system health details, and use iDRAC Direct to easily deploy or modify settings across multiple servers with a USB key or laptop, eliminating the potential for configuration errors. -
Innovative management with intelligent automation
The Dell OpenManage systems management portfolio includes innovative solutions that simplify and automate essential server lifecycle management tasks - making IT operations more efficient and Dell EMC servers the most productive, reliable and cost effective. Leveraging the incomparable agent-free capabilities of the embedded integrated Dell Remote Access Controller (IDRAC) with Lifecycle Controller technology, server deployment, configuration and updates are streamlined across the OpenManage portfolio and through integration with third-party management solutions.
 - Dell PowerEdge R630 - rack-mountable - Xeon E5-2650V3 2.3 GHz - 32 GB - HDD 300 GB
 - Server - rack-mountable
- Height (Rack Units)
 - 1U
- Server Scalability
 - 2-way
- Processor
 - 2 x Intel Xeon E5-2650V3 / 2.3 GHz (, up to 3 GHz, (10-core)
- Processor Socket
 - LGA2011-v3 Socket
- Cache Memory
 - 50 MB
- Cache Per Processor
 - 25 MB
- RAM
 - 32 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
 - RAID (SAS 12Gb/s) (Dell PERC H730)
- Server Storage Bays
 - Hot-swap 2.5"
- Hard Drive
 - HDD 300 GB (hot-swap)
- Optical Storage
 - No optical drive
- Networking
 - GigE
- Power Redundancy
- OS Provided
 - No operating system
 - 48.23 cm x 70.05 cm x 4.28 cm
 - Limited warranty - 3 years - response time: next business day
 - Server
- Product Form Factor
 - Rack-mountable - 1U
 - 2-way
- Front Accessible Bays Qty
 - 1
- Hot-Swap Bays Qty
 - 8
Processor / Chipset
- CPU
 - Intel Xeon E5-2650V3
- Clock Speed
 - 2.3 GHz
- Max Turbo Speed
 - 3 GHz
- Number of Cores
 - 10-core
- CPU Qty
 - 2
- Max CPU Qty
 - 2
- CPU Upgradability
 - Upgradable
- CPU Socket
 - LGA2011-v3 Socket
- Chipset Type
 - Intel C612
Cache Memory
- Installed Size
 - 50 MB
 - 25 MB
RAM
- Installed Size
 - 32 GB / 512 GB (max)
- Technology
 - DDR4 SDRAM - ECC
- Effective Memory Speed
 - 2133 MHz
- Rated Memory Speed
 - 2133 MHz
- Memory Specification Compliance
 - PC4-17000
- Form Factor
 - DIMM 288-pin
- Slots
 - 24 (Total)
 - Registered, dual rank
- RAM Supported
 - 768 GB Load-Reduced - ECC , 384 GB registered - ECC
Hard Drive
 - HDD - hot-swap
- Capacity
 - 1 x 300 GB
Storage Controller
 - 1 x RAID - integrated
- Controller Interface Type
 - SAS 12Gb/s
- Storage Controller Name
 - Dell PERC H730
- RAID Level
 - RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
- Buffer Size
 - 1 GB
Optical Storage
 - No optical drive
Monitor
- Monitor Type
 - None.
 - Integrated
- Ethernet Ports
 - 4 x Gigabit Ethernet
- Ethernet Controller
 - Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
 - Integrated Dell Remote Access Controller 8 Express (iDRAC8)
- Bays
 - 8 (total) / 7 (free) x hot-swap 2.5"
- Slots
 - 2 (total) / 0 (free) x CPU , 24 DIMM 288-pin , 3 PCIe 3.0
 - 4 x LAN (Gigabit Ethernet)
 - Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
 - 1+1
- Installed Qty
 - 2
- Max Supported Qty
 - 2
- Power Provided
 - 750 Watt
Operating System / Software
- OS Provided
 - 48.23 cm
 - 70.05 cm
 - 4.28 cm
