The PowerEdge R440 delivers the perfect combination of performance and density for HPC and web-tech deployments with a feature set right-sized for scale-out infrastructure environments.
More processing power
Powerful processors boost virtualized environments and performance-hungry business applications. -
High-capacity, low-power memory
Improved memory accelerates workloads, like enterprise resource planning and database applications. -
Scalable, efficient local storage
Wide range of in-server storage possibilities enables all-flash configurations, in-box hybrid tiered solutions, low-cost dense capacity platforms, and matching server-based storage with application requirements for optimal performance and value. -
Simplified, intelligent management
Dell tools accelerate time to production with enhanced local access, mobile devices for secure monitoring of the data center from your handheld device and automated processes to save time and costs, spent on daily tasks. -
Energy efficiency
Innovative power and cooling technologies such as Dell Fresh Air 2.0 allow data centers to run at constant temperatures, reducing cooling demands and enabling significant operational cost savings.
- Dell PowerEdge R440 - rack-mountable - Xeon Silver 4208 2.1 GHz - 16 GB - SSD 240 GB - no RAID
- Server - rack-mountable
- Bundled Services
- 3 Years Basic Onsite
- Height (Rack Units)
- 1U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4208 / 2.1 GHz (3.2 GHz) (8-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 512 GB (max) - DDR4 SDRAM
- Storage Controller
- RAID (Dell PERC H330)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- SSD 240 GB (hot-swap)
- Optical Storage
- No optical drive
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 48.2 cm x 67.769 cm x 4.28 cm
- Pricing Type
- Build To Plan (BTP)
- Server
- Bundled Services
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon Silver 4208
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 11 MB
- 11 MB
RAM
- Installed Size
- 16 GB / 512 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2667 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, dual rank
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 512 GB registered , 1 TB Load-Reduced
Hard Drive
- SSD - hot-swap
- Capacity
- 1 x 240 GB
Storage Controller
- RAID
- Storage Controller Name
- Dell PERC H330
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
- Interface (Bus) Type
- LAN-on-motherboard (LOM)
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 8 (total) / 7 (free) x hot-swap 2.5"
- Slots
- 1 PCIe x16
- 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB 2.0 (1 in front) , 2 x VGA (1 front, 1 rear) , 1 x USB 2.0 - micro-USB (1 in front) , 2 x USB 3.0 , 1 x serial
- Included Accessories
- Rack sliding rails, bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 550 Watt
Operating System / Software
- OS Provided
- 48.2 cm
- 67.769 cm
- 4.28 cm
- 10 °C
- 35 °C
- 10 - 80%
