Dell PowerConnect 5524P Switch Managed 24 x 10/100/1000 (POE)
Quicklinx: BTQ8WS00 Mfr#: 210-34475
The Dell 5500 series switches are designed to offer secure, fixed-port Gigabit Ethernet switching solutions to deliver full wire-speed switching performance. With 24 or 48 built-in copper Gigabit Ethernet ports in a 1U form factor, the 5500 series has a total switching capacity of up to 176 Gbps to support demanding network environments. The switches also offer simple management and scalability via a 40Gbps high-availability stacking architecture that allows you to manage up to eight switches from a single IP address, and share the dual SFP+ across the stack for uplinks to the next layer in your network. The switches are designed for Energy Efficient Ethernet (802.3az), which will reduce per port power consumption up to 50% if the link is idle, and further reduction if ports are inactive.
  • High performance
    Help meet your network switching needs, no matter the size of your organization, with the PowerConnect 5524P, featuring 24 ports of wire-speed GbE and robust security and enterprise management capabilities. USB configuration for rapid deployment and dedicated 40 Gb stacking interfaces and 10 Gb uplinks help you grow your wiring closets with your network.
  • Rapid deployment and configuration
    Help save time and deployment costs by simplifying your network rollout with PowerConnect 5500 series of Gigabit Ethernet switches. Automatically assign switch configuration and IP addresses via DHCP or local USB during initial rollout. You can configure up to eight switches in a stack without pressing a single key or setting up a console connection.
  • VoIP functionality
    Help ensure that VoIP traffic is prioritized in the event of resource contention through the voice VLAN function. LLDP-Med provides detailed network topology records, emergency call service via IP phone location information and troubleshooting data.
  • Power over Ethernet
    Help lower power consumption with the power over Ethernet (IEEE 802.3af PoE) capabilities of the PowerConnect 5524P. Designed to provide up to 15.4 Watts of power for network-attached devices, such as WLAN access points (WAPs) and voice over IP (VoIP) handsets, PoE can help simplify network installation and maintenance by reducing the need for power adapters and power planning.
Dell PowerConnect 5524P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE) + 2 x SFP+
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 128 Gbps , Forwarding performance: 65.47 Mpps
MAC addresses: 16000 , Virtual interfaces (VLANs): 4000 , QoS hardware queues: 8 , IGMP snooping entries: 256 , ACL: 3000 , ACL entries: 3000
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 2c, HTTP, HTTPS, TFTP, SSH, SSH-2, CLI
Layer 3 switching, Layer 2 switching, power over Ethernet (PoE), auto-negotiation, BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, IP address filtering, SNTP support, Weighted Random Early Detection (WRED), sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, IPv4 support, LACP support, Management Information Base (MIB)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1ad, IEEE 802.1v
44 cm x 38.1 cm x 4.3 cm
6.1 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
16K entries
Encryption Algorithm
SSL 3.0
Authentication Method
RADIUS, TACACS+
RAM
1 GB SDRAM
Flash Memory
16 MB
24 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 2 x 10Gb Ethernet - SFP+ , 1 x USB
Internal power supply
Rack Mounting Kit
Included
44 cm
38.1 cm
4.3 cm
6.1 kg
Limited warranty - parts - lifetime , Limited warranty - parts and labour - 3 years - response time: next business day
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BTQ8 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
