Dell PERC H710 Integrated RAID Controller 512MB NV Cache MiniTK
Quicklinx: C7NVWS00 Mfr#: 405-12145
The PERC H710 a mid-range internal RAID solution based on LSI's Thunderbolt (2208) ROC from Dell, which offers dual PPC 600 MHz cores (without Fast Path support), along with 6 Gb/s SAS. The PERC H710 adapter comes with 512 MB of integrated 1333 MHz DDR3 cache for quick storage. This PCIe 2.0 based card supports PowerEdge internal storage.
  • Enhanced compatibility
    Designed specifically for PC systems, this Dell PERC H710 Integrated RAID Controller ensures seamless integration and performance, enhancing your system's overall functionality.
  • Robust data transfer
    With a data transfer rate of 6 Gbit/s and support for SAS 6Gb/s interface, this RAID controller facilitates swift and efficient data movement, making it ideal for high-demand environments.
  • Expansive storage support
    Capable of supporting up to 32 storage devices, this controller offers the flexibility to manage a vast array of disks, making it perfect for extensive data storage solutions.
  • Versatile RAID levels
    Supporting multiple RAID levels, including RAID 0, 1, 10, 5, 50, 6, and 60, the Dell PERC H710 provides a range of options for data redundancy, performance, and security according to your needs.
Dell PERC H710 Integrated RAID Controller - storage controller (RAID) - SAS 6Gb/s - PCIe 2.0
Storage controller (RAID)
Bus Type
PCIe 2.0
SAS 6Gb/s
Data Transfer Rate
6 Gbit/s
Buffer Size
512 MB
Supported Devices
Disk array (RAID)
Max Storage Devices Qty
32
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
3-year warranty
PowerEdge R320, R420, R420xr, R520, R620, R720, R720xd
Host Bus
PCIe 2.0
Storage Controller
SAS 6Gb/s
Data Transfer Rate
6 Gbit/s
Buffer Size
512 MB
Supported Devices
Disk array (RAID)
32
RAID Level
2 x SAS 6Gb/s (internal)
Non-Volatile Cache
Limited warranty - 3 years
Dell PowerEdge R320, R420, R420xr, R520, R620, R720, R720xd
