Increase productivity for specialized users in a single array offering crisp text, graphs and colors with this Dell multi-client monitor.
4K large screen experience
The 43 inch display with high-performance monitor scalar offers exceptional clarity up to Ultra HD 4K. -
Multi-client capabilities
Connect up to four independent clients to a single monitor with customized views, all without bezel breaks, so you can take total command of your tasks. -
Simplify multi-monitor setups
Fewer cables, single mount setup and RS232 connection offer easy manageability. -
Clear collaboration
Colors stay consistent across wide-angle viewing up to 178°, for impressive visibility in group settings. -
Easy on the eyes
The true matte finish and low reflection mean you can work comfortably, even on long days.
- Dell P4317Q - LED monitor - 4K - 43"
- LED-backlit LCD monitor - 43"
- Energy Class
- Class B
- Energy Consumption per Year
- 102 kWh
- Power Consumption (On mode)
- 70 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 (DisplayPort: 60 Hz, Mini DisplayPort: 60 Hz, HDMI: 30 Hz)
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms
- Colour Support
- 1.06 billion colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- 2xHDMI(MHL), VGA, DisplayPort, Mini DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 2H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 97.31 cm x 25 cm x 65.8 cm
- 17.41 kg
- Display Type
- Energy Class
- Class B
- 102 kWh
- Diagonal Size
- 43"
- Viewable Size
- 42.51"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- 8 ms
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Picture in picture, picture by picture, Dell Custom Color, Transition Minimised Differential Signaling (TMDS) technology
- 97.31 cm x 25 cm x 65.8 cm - with stand
- 17.41 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 8 Watt
- 2 x MHL / HDMI , DisplayPort , VGA , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-in (mini-jack) , Headphones (mini-jack) , Serial
Mechanical
- Tilt
- Tilt Angle
- -5/+10
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
- Mounting Kit
- Optional
- Security Slot Type
- Kensington security slot
- Input Voltage
- 70 W
- Power Consumption (Typical)
- 70 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Display drivers, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 97.31 cm - depth: 25 cm - height: 65.8 cm - weight: 17.41 kg , Without stand - width: 97.31 cm - depth: 8.3 cm - height: 56.64 cm - weight: 14.11 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
