Productivity that pulls you inFocus like never before on this immersive, curved monitor with a WQHD screen, improved cable management and up to 65W of power delivery.
- Dell P3421W - LED monitor - curved - 34.14" - with 3-year Basic Advanced Exchange
- LED-backlit LCD monitor - 34.14"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/347530
- Energy Class
- Class F
- Power Consumption (On mode)
- 31.5 W
- Curved Screen
- USB 3.2 Gen 1 hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 81.57 cm x 23.74 cm x 39.11 cm
- 10.8 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 688 kg carbon emissions
- DisplayPort 1.2
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Designed For
- Latitude 5320, 5520; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 34.14"
- Curved Screen
- Yes (3800R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 85 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Flicker Free technology, Dell Easy Arrange, Dell ComfortView, 3-sided bezeless, 99% sRGB colour gamut
- Black
- 81.57 cm x 23.74 cm x 39.11 cm - with stand
- 10.8 kg
- HDMI , DisplayPort 1.2 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream , 2 x USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- VESA interface support, security lock
- DisplayPort 1.2
- Input Voltage
- 31.5 W
- Power Consumption SDR (On mode)
- 31.5 kWh/1000h
- Power Consumption (Typical)
- 32.75 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 81.57 cm - depth: 23.74 cm - height: 39.11 cm - weight: 10.8 kg , Without stand - width: 81.57 cm - depth: 5.84 cm - height: 36.6 cm - weight: 6.7 kg
- Shipping Weight
- 14.9 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 119
- Manufacturing (kg CO2e)
- 395.05
- Logistics (kg CO2e)
- 73.8
- Use (kg CO2e)
- 214
- EOL (kg CO2e)
- 4.24
- Total Carbon w/o Use Phase (kg CO2e)
- 474
- PAIA Version
- 1.2.10, 2020
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell XPS 13 9310, 15 9510
