Dell P3223QE 31.5" 3840x2160 5ms HDMI DisplayPort USB-C Hub Monitor
Quicklinx: HRZRWS00 Mfr#: DELL-P3223QE
Hurry, only 2 left in stock!
£446.90 ex VAT
£536.28 inc VAT
Experience outstanding power, clarity and detail on a brilliant 31.5-inch, 4K hub monitor. Easily connect to a variety of devices with extensive connectivity ports, including HDMI, DisplayPort, USB-C, RJ45.
Designed with wellness in mind: ComfortView Plus, an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color. Beautifully functional: the stunning black finish and small base compliment an improved cable management system that hides cords in the monitor riser. Convenient adjustability: experience made-for-you comfort by tilting, swiveling, pivoting and adjusting the height of your monitor for optimal viewing comfort.
  • Maximize your attention to detail with a 4K screen
  • Custom set up for maximum efficiency
  • Turn your workspace into an organized productivity hub
    Jumpstart productivity: simply press the monitor power button and the power sync feature seamlessly starts your monitor and connected Dell PC, even when the laptop lid is closed. Clutter-free setup: your monitor serves as your own productivity hub with RJ45 for wired Ethernet connectivity and USB-C providing up to 90 W power delivery, all in a clutter-free setup.
  • Advanced multitasking with Dell display manager
    Productive at every level: easy arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities. Seamless transitions: the auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. The key to convenience: shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. More ways to manage: asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Green thinking: for today and tomorrow
    Environmental standards: this monitor meets the latest regulatory and environmental standards such as ENERGY STAR and TCO certified edge, and is EPEAT Goldi registered. Energy conservation: save energy with PowerNapi, a feature that dims or puts your monitor to sleep when it's not in use. Advancing sustainability: Dell is committed to reducing environmental impact throughout the product lifecycle.
Dell P3223QE - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Class
Class F
USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.18159 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
71.24 cm x 23.317 cm x 46.867 cm
9.9 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
752 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3 years Advanced Exchange Service - Disti SNS
Display Type
Energy Class
Class F
Diagonal Size
31.5"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.18159 mm
Pixel Per Inch
139.87
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
71.24 cm x 23.317 cm x 46.867 cm - with stand (lowest position)
9.9 kg
HDMI (HDCP 2.2) , DisplayPort 1.4 (HDCP 2.2) , USB-C 3.2 Gen 1 upstream (power up to 90W) , 4 x USB 3.2 Gen 1 downstream , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm, VESA
Cable tie
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C to USB-A cable - 1.8 m , 1 x USB-C to USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
30.6 kWh/1000h
Power Consumption (Max)
180 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 71.24 cm - depth: 23.317 cm - height: 61.867 cm - weight: 9.9 kg , Without stand - width: 71.24 cm - depth: 5.618 cm - height: 41.717 cm - weight: 5.28 kg
Shipping Weight
13.38 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
188
Manufacturing (kg CO2e)
446
Logistics (kg CO2e)
67
Use (kg CO2e)
231
EOL (kg CO2e)
8
Total Carbon w/o Use Phase (kg CO2e)
520
PAIA Version
1.3.1
Bundled Services
20 - 80% (non-condensing)
HRZR Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
HRZR Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £58.86
HRZR Dell Dell Pro Wireless Mouse MS5120W Black In Stock £24.76
Brand: Dell
