Connect to productivity. Certified by TÜV for 4-star eye comfort, this 27-inch FHD hub monitor offers enhanced visual comfort and offers up to 90W of power delivery.
Improved ComfortView Plus
Reduces harmful blue light emissions to =35%, for all-day comfort without sacrificing color. -
Refresh rate
100 Hz refresh rate delivers less flicker, more seamless scrolling and smoother motion. -
Vivid colors
Wide color coverage with up to 16.7 m displayable colors of 99% sRGB. -
Work in clear details
This ultra-thin bezel monitor supports multi-OS environments. -
Color consistency
Consistent, vibrant colors across wide viewing angles enabled by In-Plane Switching (IPS) technology. -
1500:1 contrast ratio
For deeper blacks and brighter whites. -
Single-cable solution
Transmit video, data, and up to 90W power delivery all at once with USB-C. -
Extensive connectivity
Wide variety of ports for all your accessories and RJ45 delivering stable Ethernet. -
Quick access USB ports
Including a USB-C downstream that delivers up to 15W of power. -
Design innovation
This monitor has been thoughtfully crafted with sustainable materials including 85% recycled plastics with post-consumer recycled plastic and closed-loop ITE-derived plastic, 50% recycled steel, 100% recycled aluminum and at least 20% recycled glass. -
Energy conservation
Using PowerNap mode in Dell Display Manager lowers energy use by up to 14.8%. -
Excellence in environmental standards
This monitor is certified ENERGY STAR 8.0, carries the TCO Certified Edge designation, and is registered EPEAT Gold with Climate+. With Climate+, this monitor has met industry best practices around decarbonization.
- Dell P2725HE - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1874340
- Energy Class
- Class D
- Power Consumption (On mode)
- 16.2 W
- USB 3.2 Gen 1/USB-C hub, USB PD 90 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 61.068 cm x 19.228 cm x 38.456 cm
- 6.01 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 207 kg carbon emissions
- Plug and Play, RoHS, BFR-free, PVC-free
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Pixel Per Inch
- 81.57
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
- 61.068 cm x 19.228 cm x 38.456 cm - with stand (lowest position)
- 6.01 kg
- HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode with Power Delivery (DisplayPort Alt Mode, power up to 90W) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W) , LAN
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Cable tie
- Cables Included
- 1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 2 cable - 1 m
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16.2 W
- Power Consumption SDR (On mode)
- 16.2 kWh/1000h
- Power Consumption (Typical)
- 16.6 watt
- Power Consumption (Max)
- 180 watt
- Power Consumption Stand by
- 0.4 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.068 cm - depth: 19.228 cm - height: 38.456 cm - weight: 6.01 kg , With stand (highest position) - width: 61.068 cm - depth: 19.228 cm - height: 53.456 cm - weight: 6.01 kg , Without stand - width: 61.068 cm - depth: 5.003 cm - height: 35.471 cm - weight: 4.36 kg
- Shipping Weight
- 8.67 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 102.05
- Logistics (kg CO2e)
- 16.35
- Use (kg CO2e)
- 79.9
- EOL (kg CO2e)
- 8.69
- Total Carbon w/o Use Phase (kg CO2e)
- 127.1
- PAIA Version
- GaBi version 1, 2024
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £109.85 |
Other bundles (1)
Dell SB521A Magnetic Sound bar | In Stock | £30.78 |
