Dell P2723QE 27" 3840x2160 5ms HDMI DisplayPort USB-C Hub IPS LED Monitor
Quicklinx: GRMTWS00 Mfr#: DELL-P2723QE
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: HDMI, USB-C, DisplayPort
£292.00 ex VAT
£350.40 inc VAT
Experience pure productivity on a 27-inch 4K monitor with extensive connectivity and ComfortView Plus.
Dell P2723QE - LED monitor - 4K - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service)
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1054915
Energy Class
Class F
Power Consumption (On mode)
26 W
USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
61.16 cm x 18.5 cm x 53.52 cm
7.21 kg
TAA Compliant
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
727 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Viewable Size
26.96"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
61.16 cm x 18.5 cm x 53.52 cm - with stand
7.21 kg
HDMI (HDCP 2.3) , DisplayPort 1.4 (HDCP 2.3) , USB-C 3.2 Gen 1 upstream (power up to 90W) , 4 x USB 3.2 Gen 1 downstream , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to C - 1.8 m , 1 x USB-C to USB-C cable - 1 m
TAA Compliant
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
169 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.16 cm - depth: 18.5 cm - height: 53.52 cm - weight: 7.21 kg , Without stand - weight: 5.05 kg
Shipping Weight
9.68 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
172
Manufacturing (kg CO2e)
381.06
Logistics (kg CO2e)
86.6
Use (kg CO2e)
254
EOL (kg CO2e)
5.49
Total Carbon w/o Use Phase (kg CO2e)
473
PAIA Version
1.3.0, 2021
Bundled Services
Accessories (1)
GRMT Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (3)
GRMT Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £150.33
GRMT Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GRMT Dell Dell Pro Wireless Mouse MS5120W Black In Stock £24.76
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Interfaces: DisplayPort
Brand: Dell
