Dell P2723QE 27" 3840x2160 5ms HDMI DisplayPort USB-C Hub IPS LED Monitor
Quicklinx: GRMTWS00 Mfr#: DELL-P2723QE
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
More than 50 In Stock
£352.22 ex VAT
£422.66 inc VAT
Standard delivery Delivered within 3-5 working days
Experience pure productivity on a 27-inch 4K monitor with extensive connectivity and ComfortView Plus.
Dell P2723QE - LED monitor - 4K - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service)
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1054915
Energy Class
Class F
Power Consumption (On mode)
26 W
USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
61.16 cm x 18.5 cm x 53.52 cm
7.21 kg
TAA Compliant
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
727 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class F
Diagonal Size
27"
Viewable Size
26.96"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
61.16 cm x 18.5 cm x 53.52 cm - with stand
7.21 kg
HDMI (HDCP 2.3) , DisplayPort 1.4 (HDCP 2.3) , USB-C 3.2 Gen 1 upstream (power up to 90W) , 4 x USB 3.2 Gen 1 downstream , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to C - 1.8 m , 1 x USB-C to USB-C cable - 1 m
TAA Compliant
Input Voltage
26 W
26 kWh/1000h
Power Consumption (Typical)
169 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.16 cm - depth: 18.5 cm - height: 53.52 cm - weight: 7.21 kg , Without stand - weight: 5.05 kg
Shipping Weight
9.68 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
172
Manufacturing (kg CO2e)
381
Logistics (kg CO2e)
87
Use (kg CO2e)
254
EOL (kg CO2e)
5
Total Carbon w/o Use Phase (kg CO2e)
473
PAIA Version
1.3.0
Bundled Services
Accessories (1)
GRMT Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (1)
GRMT Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GRMT 050583
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £248.67
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
Stock Status: Used Stock
