Dell P2723DE 27" 2560 x1440 8ms HDMI DP USB LED LCD Monitor
Quicklinx: GVZZWS00 Mfr#: DELL-P2723DE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
More than 50 In Stock
£263.10 ex VAT
£315.72 inc VAT
Experience pure productivity on a 27-inch QHD monitor featuring extensive connectivity and ComfortView Plus.
  • Designed with wellness in mind
    ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
  • Color consistency comes standard
    See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With 99% sRGB coverage, you get precise colors right out of the box.
  • Beautifully functional
    The stunning black finish and small base complement an improved cable management system that hides cords in the monitor riser.
  • Moves with you
    Optimize your monitor's orientation by tilting, swiveling and adjusting the height to a maximum of 5.9 inch.
  • Extensive connectivity
    Easily connect to your devices with DisplayPort (in), DisplayPort (out), USB-C, HDMI, 4x SuperSpeed USB 5 Gbps and more.
  • Clutter-free setup
    Your monitor serves as your own productivity hub with RJ45 for wired Ethernet connectivity and USB-C providing up to 90 W power delivery, all in a clutter-free setup.
  • Jumpstart productivity
    Simply press the monitor power button and the power sync feature seamlessly starts your monitor and connected Dell PC, even when the laptop lid is closed.
  • Environmental standards
    This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as EnergyStar, and TCO Certified Edge, and is EPEAT Goldi registered.
Dell P2723DE - LED monitor - QHD - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service)
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1057602
Energy Class
Class F
USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
61.16 cm x 19.01 cm x 53.52 cm
7.34 kg
TAA Compliant
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
642 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class F
Diagonal Size
27"
Viewable Size
26.96"
Built-in Devices
USB-C hub
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
61.16 cm x 19.01 cm x 53.52 cm - with stand
7.34 kg
HDMI (HDCP 1.4) , DisplayPort (HDCP 1.4) , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) , 4 x USB 3.2 Gen 1 downstream , DisplayPort output (HDCP 1.4, MST) , LAN (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 mm
Security lock slot (cable lock sold separately), VESA interface support
Cable tie
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 2 cable - 1 m , 1 x USB-C 3.2 Gen 1 cable - USB Type C to A - 1.8 m
TAA Compliant
Input Voltage
26 kWh/1000h
Power Consumption (Max)
175 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.16 cm - depth: 19.01 cm - height: 53.52 cm - weight: 7.34 kg , Without stand - weight: 5.07 kg
Shipping Weight
9.78 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
151
Manufacturing (kg CO2e)
333
Logistics (kg CO2e)
86
Use (kg CO2e)
217
EOL (kg CO2e)
5
Total Carbon w/o Use Phase (kg CO2e)
425
PAIA Version
1.3.0
Bundled Services
Accessories (1)
GVZZ Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (1)
GVZZ Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
