Experience pure productivity on a 27-inch QHD monitor featuring extensive connectivity and ComfortView Plus.
Designed with wellness in mind
ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color. -
Color consistency comes standard
See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With 99% sRGB coverage, you get precise colors right out of the box. -
Beautifully functional
The stunning black finish and small base complement an improved cable management system that hides cords in the monitor riser. -
Moves with you
Optimize your monitor's orientation by tilting, swiveling and adjusting the height to a maximum of 5.9 inch. -
Extensive connectivity
Easily connect to your devices with DisplayPort (in), DisplayPort (out), USB-C, HDMI, 4x SuperSpeed USB 5 Gbps and more. -
Clutter-free setup
Your monitor serves as your own productivity hub with RJ45 for wired Ethernet connectivity and USB-C providing up to 90 W power delivery, all in a clutter-free setup. -
Jumpstart productivity
Simply press the monitor power button and the power sync feature seamlessly starts your monitor and connected Dell PC, even when the laptop lid is closed. -
Environmental standards
This monitor uses 85% PCR (Post-consumer Recyclable) plastic in the design and meets the latest environmental standards such as EnergyStar, and TCO Certified Edge, and is EPEAT Goldi registered.
- Dell P2723DE - LED monitor - QHD - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service)
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1057602
- Energy Class
- Class F
- USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 61.16 cm x 19.01 cm x 53.52 cm
- 7.34 kg
- TAA Compliant
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 642 kg carbon emissions
- RoHS, NFPA 99, BFR-free, PVC-free
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Viewable Size
- 26.96"
- Built-in Devices
- USB-C hub
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED edgelight backlight
- Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
- 61.16 cm x 19.01 cm x 53.52 cm - with stand
- 7.34 kg
- HDMI (HDCP 1.4) ¦ DisplayPort (HDCP 1.4) ¦ USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 90W) ¦ 4 x USB 3.2 Gen 1 downstream ¦ DisplayPort output (HDCP 1.4, MST) ¦ LAN (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- Cable tie
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m ¦ 1 x USB-C 3.2 Gen 2 cable - 1 m ¦ 1 x USB-C 3.2 Gen 1 cable - USB Type C to A - 1.8 m
- TAA Compliant
- Input Voltage
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Max)
- 175 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 61.16 cm - depth: 19.01 cm - height: 53.52 cm - weight: 7.34 kg ¦ Without stand - weight: 5.07 kg
- Shipping Weight
- 9.78 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 151
- Manufacturing (kg CO2e)
- 332.78
- Logistics (kg CO2e)
- 86.4
- Use (kg CO2e)
- 217
- EOL (kg CO2e)
- 5.46
- Total Carbon w/o Use Phase (kg CO2e)
- 425
- PAIA Version
- 1.3.0, 2021
- Bundled Services
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
Other bundles (3)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £133.92 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell Dell Pro Wireless Mouse MS5120W Black | In Stock | £24.76 |
