Stay focused on a 27-inch QHD monitor optimized to deliver high performance details and clarity.
- Dell P2723D - LED monitor - QHD - 27" - TAA Compliant - with 3-year Basic Advanced Exchange (PL - 3-year Advanced Exchange Service)
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1057546
- Energy Class
- Class E
- Power Consumption (On mode)
- 21 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- 61.16 cm x 19.01 cm x 53.52 cm
- 6.76 kg
- TAA Compliant
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 586 kg carbon emissions
- RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free
- Bundled Services
- 3 years Advanced Exchange Basic Warranty (PL - 3 years Advanced Exchange Service)
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Viewable Size
- 26.96"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED edgelight backlight
- Arsenic-free glass
- 61.16 cm x 19.01 cm x 53.52 cm - with stand
- 6.76 kg
- DisplayPort 1.2 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 cable - USB Type A to B
- TAA Compliant
- Input Voltage
- 21 W
- Power Consumption SDR (On mode)
- 21 kWh/1000h
- Power Consumption (Max)
- 55 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 61.16 cm - depth: 19.01 cm - height: 53.52 cm - weight: 6.76 kg , Without stand - weight: 4.54 kg
- Shipping Weight
- 9.2 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 137
- Manufacturing (kg CO2e)
- 307.75
- Logistics (kg CO2e)
- 81.5
- Use (kg CO2e)
- 192
- EOL (kg CO2e)
- 5.12
- Total Carbon w/o Use Phase (kg CO2e)
- 394
- PAIA Version
- 1.3.0, 2021
- Bundled Services
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £166.38 |
Other bundles (3)
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
Dell Thunderbolt Dock WD22TB4 180W | In Stock | £170.53 |
Dell Dell Pro Wireless Mouse MS5120W Black | In Stock | £21.31 |
