Dell P2722HE 27" 1920x1080 8ms HDMI DisplayPort USB-C Hub IPS LED MonitorMonitor
Quicklinx: GM93WS00 Mfr#: DELL-P2722HE
Stay productive, no matter where you work. Reduce harmful blue light with this sleek 27-inch FHD hub monitor with ComfortView Plus.
  • Comfort without sacrificing color
    Optimize eye comfort with ComfortViewPlus, an always-on, built-in screen that reduces potentially harmful blue light emissions while delivering excellent color accuracy.
  • Color consistency comes standard
    See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With 99% sRGB coverage, you get precise colors right out of the box.
  • Sleek, stylish and organized
    Hide cords in the monitor riser to keep things organized. This sleek monitor has a three-sided ultra-thin bezel, small base and an improved, easy-to-use cable management system.
  • Comfort is key
    Tilt, swivel, pivot and adjust the height of your monitor (150mm height adjustment range) for extra comfort during work.
  • Single-cable convenience
    Reduce cable clutter with USB-C connectivity, which offers the flexibility of connecting to multi-vendor USB-C systems and saves up to 72% of workspace setup time, reduces cable clutter and enables quick transitions from the desk.
  • Extensive connectivity
    Easily connect to a variety of devices with extensive connectivity ports, including HDMI, DisplayPort, DisplayPort (Out), USB-C, RJ45 and 4x SuperSpeed USB 5Gbps.
Dell P2722HE - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/553243
Energy Class
Class D
Power Consumption (On mode)
17.1 W
USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
60.99 cm x 19.01 cm x 38.415 cm
6.81 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
597 kg carbon emissions
RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520; Precision 7560; Vostro 14 5410, 15 5510; XPS 13 9310
Display Type
Energy Class
Class D
Diagonal Size
27"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
60.99 cm x 19.01 cm x 38.415 cm - with stand (lowest position)
6.81 kg
DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , HDMI (HDCP 1.4) , USB-C 3.1 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m
Input Voltage
17.1 W
17.1 kWh/1000h
Power Consumption (Typical)
16.99 Watt
Power Consumption (Max)
132 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - width: 60.99 cm - depth: 5.215 cm - height: 35.96 cm - weight: 4.92 kg , With stand (highest position) - width: 60.99 cm - depth: 53.415 cm - height: 19.01 cm - weight: 6.81 kg
Shipping Weight
9.62 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
104
Manufacturing (kg CO2e)
372
Logistics (kg CO2e)
49.7
Use (kg CO2e)
172
EOL (kg CO2e)
2.78
Total Carbon w/o Use Phase (kg CO2e)
425
PAIA Version
1.2.15, 2021
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510 , Dell XPS 13 9310
Accessories (1)
GM93 Dell Dual Monitor Stand - MDS19 In Stock £145.32
Other bundles (1)
GM93 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £47.74
