Stay productive, no matter where you work. Reduce harmful blue light with this sleek 27-inch FHD hub monitor with ComfortView Plus.
Comfort without sacrificing color
Optimize eye comfort with ComfortViewPlus, an always-on, built-in screen that reduces potentially harmful blue light emissions while delivering excellent color accuracy. -
Color consistency comes standard
See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology. With 99% sRGB coverage, you get precise colors right out of the box. -
Sleek, stylish and organized
Hide cords in the monitor riser to keep things organized. This sleek monitor has a three-sided ultra-thin bezel, small base and an improved, easy-to-use cable management system. -
Comfort is key
Tilt, swivel, pivot and adjust the height of your monitor (150mm height adjustment range) for extra comfort during work. -
Single-cable convenience
Reduce cable clutter with USB-C connectivity, which offers the flexibility of connecting to multi-vendor USB-C systems and saves up to 72% of workspace setup time, reduces cable clutter and enables quick transitions from the desk. -
Extensive connectivity
Easily connect to a variety of devices with extensive connectivity ports, including HDMI, DisplayPort, DisplayPort (Out), USB-C, RJ45 and 4x SuperSpeed USB 5Gbps.
- Dell P2722HE - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/553243
- Energy Class
- Class D
- Power Consumption (On mode)
- 17.1 W
- USB 3.2 Gen 1/USB-C hub, USB PD 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 60.99 cm x 19.01 cm x 38.415 cm
- 6.81 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 597 kg carbon emissions
- RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560; Vostro 14 5410, 15 5510; XPS 13 9310
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Pixel Per Inch
- 82
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
- 60.99 cm x 19.01 cm x 38.415 cm - with stand (lowest position)
- 6.81 kg
- DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , HDMI (HDCP 1.4) , USB-C 3.1 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 65W) , 4 x USB 3.2 Gen 1 downstream , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m
- Input Voltage
- 17.1 W
- Power Consumption SDR (On mode)
- 17.1 kWh/1000h
- Power Consumption (Typical)
- 16.99 watt
- Power Consumption (Max)
- 132 watt
- Power Consumption Stand by
- 0.2 watt
- 0.2 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 60.99 cm - depth: 5.215 cm - height: 35.96 cm - weight: 4.92 kg , With stand (highest position) - width: 60.99 cm - depth: 53.415 cm - height: 19.01 cm - weight: 6.81 kg
- Shipping Weight
- 9.62 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 104
- Manufacturing (kg CO2e)
- 372
- Logistics (kg CO2e)
- 49.7
- Use (kg CO2e)
- 172
- EOL (kg CO2e)
- 2.78
- Total Carbon w/o Use Phase (kg CO2e)
- 425
- PAIA Version
- 1.2.15, 2021
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell Vostro 14 5410, 15 5510 , Dell XPS 13 9310
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £43.18 |
