Stay productive, no matter where you work. Reduce harmful blue light with this sleek 27-inch FHD monitor featuring Comfort View Plus technology.
 - Dell P2722H - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/545529
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 15 W
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.3114 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- Response Time
 - 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 100-240 V (50/60 Hz)
 - 60.99 cm x 19.01 cm x 53.41 cm
 - 6.77 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 517 kg carbon emissions
 - RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
 - 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 27"
- Built-in Devices
 - USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.3114 mm
- Pixel Per Inch
 - 82
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1
- Colour Support
- Colour Gamut
 - 99% sRGB
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
- Backlight Technology
 - WLED
 - LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
 - 60.99 cm x 19.01 cm x 53.41 cm - with stand
 - 6.77 kg
 - DisplayPort 1.2 (HDCP 1.4) , VGA , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
 - -5/+21
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
 - 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable
- Input Voltage
 - 15 W
- Power Consumption SDR (On mode)
 - 15 kWh/1000h
- Power Consumption (Max)
 - 55 Watt
- Power Consumption Stand by
 - 0.3 Watt
- Power Consumption Sleep
 - 0.3 Watt
 - 0.2 Watt
- Dimensions & Weight Details
 - With stand - width: 60.99 cm - depth: 19.01 cm - height: 53.41 cm - weight: 6.77 kg , Without stand - weight: 4.38 kg
- Shipping Weight
 - 9.31 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
 - 99
- Manufacturing (kg CO2e)
 - 338.41
- Logistics (kg CO2e)
 - 46.9
- Use (kg CO2e)
 - 129
- EOL (kg CO2e)
 - 2.62
- Total Carbon w/o Use Phase (kg CO2e)
 - 388
- PAIA Version
 - 1.2.15, 2021
- Bundled Services
Accessories (1)
                        Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (2)
                        Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £56.48 |
                        Dell Dell Pro Wireless Mouse MS5120W Black | In Stock | £19.58 |
