Dell P2722H 27" 1920x1080 8ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: GHGPWS00 Mfr#: DELL-P2722H
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, VGA (HD-15), DisplayPort
£150.53 ex VAT
£180.63 inc VAT
Stay productive, no matter where you work. Reduce harmful blue light with this sleek 27-inch FHD monitor featuring Comfort View Plus technology.
Dell P2722H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/545529
Energy Class
Class D
Power Consumption (On mode)
15 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
60.99 cm x 19.01 cm x 53.41 cm
6.77 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
517 kg carbon emissions
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class D
Diagonal Size
27"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
60.99 cm x 19.01 cm x 53.41 cm - with stand
6.77 kg
DisplayPort 1.2 (HDCP 1.4) , VGA , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable
Input Voltage
15 W
15 kWh/1000h
Power Consumption (Max)
55 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Dimensions & Weight Details
With stand - width: 60.99 cm - depth: 19.01 cm - height: 53.41 cm - weight: 6.77 kg , Without stand - weight: 4.38 kg
Shipping Weight
9.31 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
99
Manufacturing (kg CO2e)
338.41
Logistics (kg CO2e)
46.9
Use (kg CO2e)
129
EOL (kg CO2e)
2.62
Total Carbon w/o Use Phase (kg CO2e)
388
PAIA Version
1.2.15, 2021
Bundled Services
Accessories (1)
GHGP Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (3)
GHGP Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
GHGP Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £59.08
GHGP Dell Dell Pro Wireless Mouse MS5120W Black In Stock £17.36
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: Dell
