The Dell P2425HE monitor is designed to meet the needs of professionals seeking a high-performance display with advanced connectivity and ergonomic features. This 24-inch monitor delivers stunning visuals with its Full HD resolution and 99% sRGB color gamut, making it perfect for precision tasks that require color accuracy. Its comprehensive connectivity options, including USB-C with power delivery, allow for a streamlined workspace, reducing cable clutter and enhancing productivity. The monitor's ergonomic design, featuring an adjustable stand and integrated cable management, ensures comfort during extended use. Additionally, its commitment to environmental sustainability is evident in its ENERGY STAR certification and EPEAT Gold rating, making it an ideal choice for eco-conscious consumers. Whether for work or leisure, the Dell P2425HE offers a blend of performance, convenience, and sustainability.
                Enhanced connectivityEquipped with a USB-C 3.2 Gen 2 cable and DisplayPort 1.4, the Dell P2425HE monitor offers versatile connectivity options, supporting high-speed data transfer and power delivery up to 90 W. This feature simplifies the workspace by reducing cable clutter and making it easier to connect to laptops and other devices.
                Superior visual experienceThe 24-inch display boasts a 99% sRGB color gamut and Full HD 1080p resolution, ensuring vivid and accurate colors. With Dell ComfortView Plus, Flicker-Free technology, and Low Blue Light technology, it offers a comfortable viewing experience, reducing eye strain during long work sessions.
                Ergonomic designFeaturing a 3-sided bezel-less monitor with an adjustable stand, the Dell P2425HE allows for seamless multi-monitor setups and optimal viewing angles. Integrated cable management keeps the workspace tidy, enhancing productivity and comfort.
                Eco-friendly choiceWith ENERGY STAR certification, EPEAT Gold rating, and constructed from arsenic-free glass and mercury-free LED lighting, the Dell P2425HE is an environmentally responsible choice, minimizing its carbon footprint while delivering exceptional performance.
- Dell P2425HE - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1865677
- Energy Class
- Class D
- Power Consumption (On mode)
- 13.9 W
- Daisy Chaining
- USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 53.864 cm x 18.175 cm x 36.4 cm
- 5.44 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 168 kg carbon emissions
- Plug and Play, RoHS, BFR-free, PVC-free
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.81"
- Daisy Chaining
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 92.53
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 110 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
- 53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
- 5.44 kg
- HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode with Power Delivery (DisplayPort Alt Mode, power up to 90W) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W) , LAN
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Cable tie
- Cables Included
- 1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 2 cable - 1 m
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.9 W
- Power Consumption SDR (On mode)
- 13.9 kWh/1000h
- Power Consumption (Typical)
- 15.2 Watt
- Power Consumption (Max)
- 180 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.864 cm - depth: 18.175 cm - height: 36.4 cm - weight: 5.44 kg , With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm , Without stand - width: 53.864 cm - depth: 5.003 cm - height: 31.423 cm - weight: 3.69 kg
- Shipping Weight
- 7.24 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 85.34
- Logistics (kg CO2e)
- 11.59
- Use (kg CO2e)
- 68.38
- EOL (kg CO2e)
- 2.69
- Total Carbon w/o Use Phase (kg CO2e)
- 99.62
- PAIA Version
- GaBi version 1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
|  | Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (1)
|  | Dell SB521A Magnetic Sound bar | In Stock | £35.62 |
