Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: HR4CWS00 Mfr#: DELL-P2425HE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: HDMI, DisplayPort, USB-C
More than 50 In Stock
£160.21 ex VAT
£192.25 inc VAT
The Dell P2425HE monitor is designed to meet the needs of professionals seeking a high-performance display with advanced connectivity and ergonomic features. This 24-inch monitor delivers stunning visuals with its Full HD resolution and 99% sRGB color gamut, making it perfect for precision tasks that require color accuracy. Its comprehensive connectivity options, including USB-C with power delivery, allow for a streamlined workspace, reducing cable clutter and enhancing productivity. The monitor's ergonomic design, featuring an adjustable stand and integrated cable management, ensures comfort during extended use. Additionally, its commitment to environmental sustainability is evident in its ENERGY STAR certification and EPEAT Gold rating, making it an ideal choice for eco-conscious consumers. Whether for work or leisure, the Dell P2425HE offers a blend of performance, convenience, and sustainability.
  • Enhanced connectivity
    Equipped with a USB-C 3.2 Gen 2 cable and DisplayPort 1.4, the Dell P2425HE monitor offers versatile connectivity options, supporting high-speed data transfer and power delivery up to 90 W. This feature simplifies the workspace by reducing cable clutter and making it easier to connect to laptops and other devices.
  • Superior visual experience
    The 24-inch display boasts a 99% sRGB color gamut and Full HD 1080p resolution, ensuring vivid and accurate colors. With Dell ComfortView Plus, Flicker-Free technology, and Low Blue Light technology, it offers a comfortable viewing experience, reducing eye strain during long work sessions.
  • Ergonomic design
    Featuring a 3-sided bezel-less monitor with an adjustable stand, the Dell P2425HE allows for seamless multi-monitor setups and optimal viewing angles. Integrated cable management keeps the workspace tidy, enhancing productivity and comfort.
  • Eco-friendly choice
    With ENERGY STAR certification, EPEAT Gold rating, and constructed from arsenic-free glass and mercury-free LED lighting, the Dell P2425HE is an environmentally responsible choice, minimizing its carbon footprint while delivering exceptional performance.
Dell P2425HE - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1865677
Energy Class
Class D
Power Consumption (On mode)
13.9 W
Daisy Chaining
USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1500:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.864 cm x 18.175 cm x 36.4 cm
5.44 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
168 kg carbon emissions
Plug and Play, RoHS, BFR-free, PVC-free
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.81"
Daisy Chaining
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.53
Brightness
250 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 110 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
5.44 kg
HDMI , DisplayPort 1.4 (HDCP 1.4) , DisplayPort output (HDCP 1.4, MST) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode with Power Delivery (DisplayPort Alt Mode, power up to 90W) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W) , LAN
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Cable tie
1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C 3.2 Gen 2 cable - 1 m
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
13.9 W
13.9 kWh/1000h
Power Consumption (Typical)
15.2 Watt
Power Consumption (Max)
180 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.864 cm - depth: 18.175 cm - height: 36.4 cm - weight: 5.44 kg , With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm , Without stand - width: 53.864 cm - depth: 5.003 cm - height: 31.423 cm - weight: 3.69 kg
Shipping Weight
7.24 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
85.34
Logistics (kg CO2e)
11.59
Use (kg CO2e)
68.38
EOL (kg CO2e)
2.69
Total Carbon w/o Use Phase (kg CO2e)
99.62
PAIA Version
GaBi version 1
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
HR4C Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (2)
HR4C Dell SB521A Magnetic Sound bar In Stock £36.88
HR4C Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
