Stay productive. Get enhanced visual comfort and seamless connectivity with this FHD monitor, certified by TÜV for 4-star eye comfort.
Improved ComfortView Plus
Reduces harmful blue light emissions to =35%, for all-day comfort without sacrificing color. -
Refresh rate
100 Hz refresh rate delivers less flicker, more seamless scrolling and smoother motion. -
Vivid colors
Wide color coverage with up to 16.7 m displayable colors of 99% sRGB. -
Color consistency
Vibrant colors across wide viewing angles enabled by In-Plane Switching (IPS) technology. -
1500:1 contrast ratio
For deeper blacks and brighter whites. -
Extensive connectivity
Wide variety of ports for all your accessories. -
Quick access USB ports
Including a USB-C downstream that delivers up to 15W of power. -
Design innovation
This monitor has been thoughtfully crafted with sustainable materials including 85% recycled plastics with post-consumer recycled plastic and closed-loop ITE-derived plastic, 50% recycled steel, 100% recycled aluminum and at least 20% recycled glass. -
Energy conservation
Using PowerNap mode in Dell Display Manager lowers energy use by up to 14.8%. -
Excellence in environmental standards
This monitor is certified ENERGY STAR 8.0, carries the TCO Certified Edge designation, and is registered EPEAT Gold with Climate+. With Climate+, this monitor has met industry best practices around decarbonization.
 - Dell P2425H - LED monitor - Full HD (1080p) - 24"
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/1865623
- Energy Class
 - Class C
- Power Consumption (On mode)
 - 11.7 W
 - USB 3.2 Gen 1 hub, USB PD 15 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 (DisplayPort: 100 Hz, HDMI: 100 Hz, VGA: 60 Hz)
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1500:1
- Response Time
 - 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare 3H hardness
- Voltage
 - AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
 - 53.864 cm x 18.175 cm x 36.4 cm
 - 4.61 kg
- Pricing Type
 - BTO
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- Carbon Footprint
 - 155 kg carbon emissions
 - Plug and Play, RoHS, BFR-free, PVC-free
- Bundled Services
 - 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
 - Class C
- Diagonal Size
 - 24"
- Viewable Size
 - 23.81"
- Built-in Devices
 - USB 3.2 Gen 1 hub
- USB Power Delivery
 - 15 Watt
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Pixel Per Inch
 - 92.53
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1500:1
- Colour Support
- Colour Gamut
 - 99% sRGB
- Response Time
- Vertical Refresh Rate
 - 48 - 100 Hz
- Horizontal Refresh Rate
 - 30 - 110 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - LED backlight
 - LED edgelight system, Flicker Free technology, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
 - 53.864 cm x 18.175 cm x 36.4 cm - with stand (lowest position)
 - 4.61 kg
 - HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , VGA , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 Gen 1 downstream (power up to 15W)
Mechanical
- Tilt Angle
 - -5/+21
- Swivel Angle
 - 90
- Rotation Angle
 - 180
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
 - 1 x DisplayPort 1.2 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
- Pricing Type
 - BTO
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 11.7 W
- Power Consumption SDR (On mode)
 - 11.7 kWh/1000h
- Power Consumption (Typical)
 - 12 Watt
- Power Consumption (Max)
 - 65 Watt
- Power Consumption Stand by
 - 0.3 Watt
 - 0.3 Watt
- Included Software
 - Dell Display Manager
- Dimensions & Weight Details
 - With stand (lowest position) - width: 53.864 cm - depth: 18.175 cm - height: 36.4 cm - weight: 4.61 kg , With stand (highest position) - width: 53.864 cm - depth: 18.175 cm - height: 49.653 cm - weight: 4.61 kg , Without stand - width: 53.864 cm - depth: 5.003 cm - height: 31.423 cm - weight: 3.12 kg
- Shipping Weight
 - 6.78 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
 - 80.6
- Logistics (kg CO2e)
 - 12.71
- Use (kg CO2e)
 - 57.66
- EOL (kg CO2e)
 - 4.03
- Total Carbon w/o Use Phase (kg CO2e)
 - 97.34
- PAIA Version
 - GaBi version 1
- Bundled Services
 - 0 °C
 - 40 °C
 - 10 - 80% (non-condensing)
Accessories (1)
                        Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (1)
                        Dell SB521A Magnetic Sound bar | In Stock | £35.62 |
