Dell P2424HT 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: J6B5WS00 Mfr#: DELL-P2424HT
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort, HDMI
More than 50 In Stock
£272.77 ex VAT
£327.32 inc VAT
Stay productive, no matter where you work. Reduce harmful blue light with this sleek monitor featuring ComfortView Plus technology.
  • Comfort without sacrificing color
    Optimize eye comfort with ComfortView Plus, an always-on, built-in screen that reduces potentially harmful blue light emissions while delivering excellent color accuracy.
  • Color consistency comes standard
    See consistent, vibrant colors across a wide viewing angle enabled by In-Plane Switching (IPS) technology.
  • Sleek, stylish and organized
    Hide cords in the monitor riser to keep things organized. This sleek monitor has a three-sided ultrathin bezel, small base and an improved, easy-to-use cable management system.
  • Comfort is key
    Tilt, swivel, pivot and adjust the height of your monitor for extra comfort during work.
  • Extensive connectivity
    Easily connect to a variety of devices with extensive connectivity ports.
  • Quick-access ports
    Easily share and deliver content via quick-access ports conveniently placed at the front of the display.
  • Easy navigation
    Navigate the menu and adjust screen settings with the easy-to-use joystick control.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
Dell P2424HT - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1465328
Energy Class
Class E
Power Consumption (On mode)
18 W
USB 3.2 Gen 1/USB-C hub, USB PD 90 watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours (6-bit + A-FRC)
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.88 cm x 24.887 cm x 32.098 cm
7.86 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
633 kg carbon emissions
RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3 years Limited Hardware Warranty with Advanced Exchange Service and Premium Panel Exchange
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB Power Delivery
90 watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 88 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus
53.88 cm x 24.887 cm x 32.098 cm - with stand (lowest position)
7.86 kg
Audio
Speakers - mono
Output Power / Channel
3 watt
Input
Touchscreen
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.2 Alt Mode with Power Delivery (power up to 90W) , 2 x USB 3.2 Gen 1 downstream , USB-C 3.2 Gen 1 downstream (power up to 15W) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 (power up to 10W) , LAN (RJ-45) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+60
Swivel Angle
60
Height Adjustment
110.52 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to C - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB-C - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
17.75 watt
Power Consumption (Max)
190 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 53.88 cm - depth: 24.887 cm - height: 32.098 cm - weight: 7.86 kg , With stand (highest position) - width: 53.88 cm - depth: 24.887 cm - height: 43.15 cm - weight: 7.86 kg , Without stand - width: 53.88 cm - depth: 5.41 cm - height: 32.098 cm - weight: 3.86 kg
Shipping Weight
10.78 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
149
Manufacturing (kg CO2e)
396.26
Logistics (kg CO2e)
53.17
Use (kg CO2e)
177.24
EOL (kg CO2e)
6.33
Total Carbon w/o Use Phase (kg CO2e)
456.05
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
Diagonal Size: 24in
Response Time: 5ms
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Dell
