Dell P2424HEB 24" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor
Quicklinx: J6B4WS00 Mfr#: DELL-P2424HEB
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
More than 50 In Stock
£256.77 ex VAT
£308.12 inc VAT
Connect like you're there with a 23.8" Full HD IPS display built for effortless collaboration.
  • Powerful webcam
    Take center stage with a 2K QHD webcam that packs a punch. The large Sony STARVIS sensor is 29.5% larger than the previous model, takes in substantial light to give you vibrant picture clarity and a vivid image.
  • Look great in low light
    Temporal (3D) and Spatial (2D) Noise Reduction automatically eliminates motion blur and grainy images in low light, while AI Auto Framing keeps you in the middle of the frame even as you move around.
  • Loud and clear
    Collaborate like you're there with built-in, dual echo cancellation mics and dual 5 W speakers, strategically positioned at the top of the monitor for an immersive audio experience.
  • Interaction secured
    The manual webcam shutter and convenient microphone mute button on this Zoom-certified monitor helps ensure that you're only communicating what you want to share, when you want to share it.
  • Easier connections
    Launch Teams meetings effortlessly with the quick access touch control on this certified for Microsoft Teams monitor.
  • Easy on the eyes
    Work without straining your eyes with the always-on, built-in ComfortView Plus, which reduces low blue light without compromising color.
  • Comfort is key
    Tilt, swivel, pivot and adjust the height of your monitor up to a maximum of 150 mm.
  • Connect to productivity
    With wired connectivity options like RJ-45 and USB-C, your monitor delivers reliable Ethernet, power, audio and video - all in a clutter-free setup.
  • Quick convenience
    Plug in whatever you need and keep it in reach with the two, super speed USB 5 Gbps (USB 3.2 Gen 1) quick-access ports. There's even space to charge your mobile phone (up to 15 W power charging) with the USB-C quick-access port.
  • Enhanced manageability
    Managing your monitor is easy with MAC Address pass-through, PXE Boot, and Wake-on-LAN conveniently built in.
  • Multitask efficiently
    Connect two PC sources to the monitor - an intelligent Auto KVM feature detects the second connected PC and seamlessly switches controls over. KVM (keyboard, video and mouse) allows you to control both PCs with a single keyboard and mouse. Plus, you can enhance efficiency?by adding a second monitor via the daisy chain feature.
Dell 24 Video Conferencing Monitor P2424HEB - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1378986
Energy Class
Class E
Power Consumption (On mode)
15.5 W
2 microphones, IR camera, proximity sensor, USB 3.2 Gen 1/USB-C hub, RGB camera, IR sensor, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Built-in Webcam
2560 x 1440 at 30 fps
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.804 cm x 18.5 cm x 40.162 cm
6.08 kg
Pricing Type
BTO
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
Carbon Footprint
582 kg carbon emissions
Plug and Play, RoHS, NFPA 99, BFR-free, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.56
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Integrated cable management, Flicker Free technology, daisy chain compatible, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, 3-sided bezeless, Dell ComfortView Plus
53.804 cm x 18.5 cm x 40.162 cm - with stand (lowest position)
6.08 kg
Built-in Webcam
Max Video Resolution
Digital Zoom
4
Privacy shutter, Auto Focus, 78° field of view, Windows Hello compatible
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1/DisplayPort 1.2 Alt Mode (power up to 90W) , DisplayPort output (MST) , USB-B 3.2 Gen 1 upstream , USB 3.2 Gen 1 (BC 1.2) , 2 x USB 3.2 Gen 1 , LAN , Audio line-out (mini-jack) , USB-C 3.2 Gen 1 downstream (data only)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot, Dell Power Button Sync
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to C - 1.8 m , 1 x USB-C cable - USB-C - 1.8 m
Software Certification
Zoom Certified, Certified for Microsoft Teams, Microsoft Cortana Certified
Pricing Type
BTO
Security Slot Type
Kensington security slot
Input Voltage
15.5 W
15.5 kWh/1000h
Power Consumption (Typical)
15.38 Watt
Power Consumption (Max)
195 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager, Dell Peripheral Manager
Windows 10, Apple macOS 12.4 or later, Windows 11 (version 21H2)
Dimensions & Weight Details
With stand (lowest position) - width: 53.804 cm - depth: 18.5 cm - height: 40.162 cm - weight: 6.08 kg , With stand (highest position) - width: 53.804 cm - depth: 18.5 cm - height: 55.162 cm - weight: 6.08 kg , Without stand - width: 53.804 cm - depth: 6.053 cm - height: 37.455 cm - weight: 4.44 kg
Shipping Weight
8.43 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
152
Manufacturing (kg CO2e)
422.44
Logistics (kg CO2e)
40.1
Use (kg CO2e)
115.16
EOL (kg CO2e)
4.7
Total Carbon w/o Use Phase (kg CO2e)
466.84
PAIA Version
1.3.2, 2022
Bundled Services
10 - 80% (non-condensing)
J6B4 Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £171.38
Diagonal Size: 24in
Response Time: 5ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Dell
