Dell P2423D 23.8" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: H3MRWS00 Mfr#: DELL-P2423D
Diagonal Size: 23.8in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: [N/A]
Interfaces: HDMI, DisplayPort
More than 50 In Stock
£177.56 ex VAT
£213.07 inc VAT
Stay focused on a 23.8-inch QHD monitor optimized to deliver high performance details and clarity.
Dell P2423D - LED monitor - QHD - 23.8" - TAA Compliant
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1057427
Energy Class
Class E
Power Consumption (On mode)
16 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2058 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.78 cm x 17.957 cm x 49.611 cm
5.45 kg
TAA Compliant
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
538 kg carbon emissions
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2058 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Arsenic-free glass
53.78 cm x 17.957 cm x 49.611 cm - with stand
5.45 kg
DisplayPort 1.2 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 cable - USB Type A to B
TAA Compliant
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Max)
55 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.78 cm - depth: 17.957 cm - height: 49.611 cm - weight: 5.45 kg , Without stand - weight: 3.44 kg
Shipping Weight
7.44 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
128
Manufacturing (kg CO2e)
298
Logistics (kg CO2e)
65
Use (kg CO2e)
170
EOL (kg CO2e)
4
Total Carbon w/o Use Phase (kg CO2e)
368
PAIA Version
1.3.0
Bundled Services
Accessories (1)
H3MR Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (4)
H3MR Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.91
H3MR Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
H3MR Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £58.86
H3MR Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £26.91
Response Time: 5ms
Speakers: [N/A]
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Dell
