See everything on the 24-inch WUXGA 16:10 monitor with versatile connectivity, a three-sided ultrathin bezel and ComfortView Plus.
Designed with wellness in mind
ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color. -
Convenient adjustability
Experience made-for-you comfort by tilting, swiveling, pivoting and adjusting the height of your monitor (150mm max) for optimal viewing comfort. -
Simple customization:
Navigate and adjust your monitor screen settings with the easy-to-use joystick control. -
Extensive connectivity
Conveniently connect to a variety of devices with extensive connectivity ports, including DisplayPort, HDMI, DVI, VGA and SuperSpeed USB 5Gbps. -
Productive at every level
Easy Arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
- Dell P2423 - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1043228
- Energy Class
- Class D
- Power Consumption (On mode)
- 14.8 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 1000:1 (dynamic)
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DVI, DisplayPort, VGA
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 53.1 cm x 17.957 cm x 51.08 cm
- 5.56 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 565 kg carbon emissions
- RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 94
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED edgelight backlight
- Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
- Black
- 53.1 cm x 17.957 cm x 51.08 cm - with stand
- 5.56 kg
- HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DVI , VGA , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
- Input Voltage
- 14.8 W
- Power Consumption SDR (On mode)
- 14.8 kWh/1000h
- Power Consumption (Max)
- 48 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.2 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 53.1 cm - depth: 17.957 cm - height: 51.08 cm - weight: 5.56 kg , Without stand - weight: 3.52 kg
- Shipping Weight
- 7.71 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 122
- Manufacturing (kg CO2e)
- 353.77
- Logistics (kg CO2e)
- 68.4
- Use (kg CO2e)
- 138
- EOL (kg CO2e)
- 4.32
- Total Carbon w/o Use Phase (kg CO2e)
- 427
- PAIA Version
- 1.3.0, 2021
- Bundled Services
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (2)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.21 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £35.35 |
