Dell P2423 24" 1920 x 1200 8ms HDMI DVI VGA USB LED LCD Monitor
Quicklinx: GSSSWS00 Mfr#: DELL-P2423
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 5ms
Speakers: None
Interfaces: DVI, DisplayPort, HDMI, VGA (HD-15)
More than 50 In Stock
£130.13 ex VAT
£156.15 inc VAT
See everything on the 24-inch WUXGA 16:10 monitor with versatile connectivity, a three-sided ultrathin bezel and ComfortView Plus.
  • Designed with wellness in mind
    ComfortView Plus - an always-on, built-in low blue light screen - reduces potentially harmful blue light emissions without compromising color.
  • Convenient adjustability
    Experience made-for-you comfort by tilting, swiveling, pivoting and adjusting the height of your monitor (150mm max) for optimal viewing comfort.
  • Simple customization:
    Navigate and adjust your monitor screen settings with the easy-to-use joystick control.
  • Extensive connectivity
    Conveniently connect to a variety of devices with extensive connectivity ports, including DisplayPort, HDMI, DVI, VGA and SuperSpeed USB 5Gbps.
  • Productive at every level
    Easy Arrange allows you to easily tile multiple applications across one or more screens with 38 pre-set window partitions and the ability to personalize up to five windows, giving you improved multitasking abilities.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
Dell P2423 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
14.8 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
WUXGA 1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DVI, DisplayPort, VGA
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
53.1 cm x 17.957 cm x 51.08 cm
5.56 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class D
Diagonal Size
24"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
94
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED edgelight backlight
Mercury free, arsenic-free glass, 3-sided bezeless, Dell ComfortView Plus
53.1 cm x 17.957 cm x 51.08 cm - with stand
5.56 kg
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DVI , VGA , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
Input Voltage
14.8 W
14.8 kWh/1000h
Power Consumption (Max)
48 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.1 cm - depth: 17.957 cm - height: 51.08 cm - weight: 5.56 kg , Without stand - weight: 3.52 kg
Shipping Weight
7.71 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
Accessories (1)
GSSS Dell Dual Monitor Stand - MDS19 In Stock £149.14
Other bundles (3)
GSSS Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.58
GSSS Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £141.12
GSSS Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.51
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: DisplayPort
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
