Dell P2422H 24" 1920 x 1080 5ms HDMI VGA Monitor
Quicklinx: GDQBWS00 Mfr#: DELL-P2422H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, VGA (HD-15)
Hurry, only 1 left in stock!
£124.61 ex VAT
£149.53 inc VAT
A better view from anywhere. Stay productive, no matter where you work. Reduce harmful blue light with this sleek 23.8-inch FHD monitor featuring ComfortView Plus technology.
Dell P2422H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/550826
Energy Class
Class C
Power Consumption (On mode)
12 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (lowest position)
53.78 cm x 17.957 cm x 36.4 cm
5.15 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
481 kg carbon emissions
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Service and Limited Hardware Warranty
Display Type
Energy Class
Class C
Diagonal Size
24"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
53.78 cm x 17.957 cm x 36.4 cm - with stand (lowest position)
5.15 kg
DisplayPort 1.2 (HDCP 1.4) , VGA , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable
Input Voltage
12 W
12 kWh/1000h
Power Consumption (Typical)
11.55 Watt
Power Consumption (Max)
46 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - width: 53.78 cm - depth: 5.215 cm - height: 31.85 cm - weight: 3.39 kg , With stand (highest position) - width: 53.78 cm - depth: 17.957 cm - height: 49.611 cm - weight: 5.15 kg
Shipping Weight
7.95 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
98
Manufacturing (kg CO2e)
327.25
Logistics (kg CO2e)
39.6
Use (kg CO2e)
111
EOL (kg CO2e)
2.22
Total Carbon w/o Use Phase (kg CO2e)
370
PAIA Version
1.2.15, 2021
Bundled Services
10 - 80% (non-condensing)
GDQB Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.73
GDQB Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £133.92
GDQB Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GDQB Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: VGA (HD-15)
Brand: Dell
