A better view from anywhere. Stay productive, no matter where you work. Reduce harmful blue light with this sleek 23.8-inch FHD monitor featuring ComfortView Plus technology.
- Dell P2422H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/550826
- Energy Class
- Class C
- Power Consumption (On mode)
- 12 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - with stand (lowest position)
- 53.78 cm x 17.957 cm x 36.4 cm
- 5.15 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 481 kg carbon emissions
- RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
- Black
- 53.78 cm x 17.957 cm x 36.4 cm - with stand (lowest position)
- 5.15 kg
- DisplayPort 1.2 (HDCP 1.4) , VGA , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable
- Input Voltage
- 12 W
- Power Consumption SDR (On mode)
- 12 kWh/1000h
- Power Consumption (Typical)
- 11.55 watt
- Power Consumption (Max)
- 46 watt
- Power Consumption Stand by
- 0.3 watt
- 0.2 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 53.78 cm - depth: 5.215 cm - height: 31.85 cm - weight: 3.39 kg , With stand (highest position) - width: 53.78 cm - depth: 17.957 cm - height: 49.611 cm - weight: 5.15 kg
- Shipping Weight
- 7.95 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 98
- Manufacturing (kg CO2e)
- 327.25
- Logistics (kg CO2e)
- 39.6
- Use (kg CO2e)
- 111
- EOL (kg CO2e)
- 2.22
- Total Carbon w/o Use Phase (kg CO2e)
- 370
- PAIA Version
- 1.2.15, 2021
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £25.61 |
Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse | In Stock | £43.18 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £25.61 |
