Dell P2419HC 23.8" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: F31HWS00 Mfr#: DELL-P2419HC
Optimize your workspace with this 23.8" monitor featuring USB-C connectivity, a small footprint and productivity-boosting features.
  • All in one
    Declutter your desk with the included USB-C cable, a single cable solution that transmits power, data, video and audio.
  • Big convenience in one cable
    Get an easy charge with USB-C, the same cable that connects your device to the monitor.
  • Connect to productivity
    Easily daisy chain up to two FHD monitors with DisplayPort 1.2 output.
  • Smooth transitions
    Conveniently connect to a variety of laptops, or switch seamlessly between users, thanks to USB-C connectivity - ideal for shared workspaces.
  • More room to work
    With a thin profile and the smallest base in its class, you can free up valuable desk space.
  • Expand your efficiency
    The three-sided ultrathin bezel design lets you enjoy an uninterrupted view of your content across multiple monitors. And, with dual monitors, you can increase your productivity by up to 18%.
  • More ways to multitask
    Work conveniently across multiple screens and select from predefined templates with the Easy Arrange feature on Dell Display Manager software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off.
  • Consistent and rich colors
    A wide viewing angle enabled by In-plane switching technology lets you see vibrant colors - no matter where you sit.
  • Clean and clutter-free
    Focus on your work while hiding away cable clutter with an improved cable management design.
  • Easy on the eyes
    This TUV Certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over extended viewing.
  • Adjust to your comfort
    Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long. Or choose from a variety of mounts and stands, including VESA, for even more flexibility.
Dell P2419HC - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
14.2 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.78 cm x 16.6 cm x 35.61 cm
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
504 kg carbon emissions
RoHS
Bundled Services
3 years Advanced Exchange Service
Latitude 5320, 5520, 7400 2-in-1; Precision 7560; XPS 13 9380, 15 9570
Display Type
Energy Class
Class D
28 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, BFR/PVC-free, Mercury free, arsenic free
53.78 cm x 16.6 cm x 35.61 cm - with stand
DisplayPort , DisplayPort output , HDMI , USB-C , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
Cable tie
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable
RoHS
Security Slot Type
Kensington security slot
Input Voltage
14.2 W
14.2 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 53.78 cm - depth: 4.28 cm - height: 32.22 cm - weight: 3.52 kg , With stand - width: 53.78 cm - depth: 16.6 cm - height: 35.61 cm
Shipping Weight
7.26 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
127
Manufacturing (kg CO2e)
342
Logistics (kg CO2e)
46
Use (kg CO2e)
112
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
391
PAIA Version
12/1/2018
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 5320, 5520, 7400 2-in-1 , Dell Precision 7560 , Dell XPS 13 9380, 15 9570
