Dell P2415Q 23.8" 3840x2160 6ms HDMI DP USB 4K LED Monitor
Quicklinx: B15VWS00 Mfr#: 210-ADZC
Diagonal Size: 23.8in
Max Resolution: 3840 x 2160
Response Time: 6ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
Hurry, only 1 left in stock!
£322.17 ex VAT
£386.60 inc VAT
Expect beautiful 4K clarity on Ultra HD monitor with high resolution, wide color coverage and reliable performance. Connect to laptops, tablets and other devices without compromising on picture quality. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle. Enjoy every detail with Dell Ultra HD 4K monitor which provides total comfort, thanks to full adjustability. Customize your viewing experience with a height-adjustable stand, or save desktop space by detaching the stand for wall mounting. With DisplayPort, you can daisy-chain two monitors side by side by connecting via the DP-in and DP-out ports, eliminating the need to link every one of your monitors to the PC and reducing cable clutter. Charge or power USB devices with a high-speed USB 3.0 charging port. Connect to MHL compatible smartphone or tablet and display content directly on the larger monitor screen via MHL. Made with premium-quality materials, this Ultra HD 4K monitor is BFR/PVC-free and has arsenic-free glass, a mercury-free LED panel, and a chassis made mostly of post-consumer recycled materials.
  • Exceptional screen clarity
    This Dell Ultra HD 4K monitor features gorgeous resolution. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford.
  • Nearly perfect color accuracy
    You can count on natural and consistent color across different mediums. You get precise color coverage right out of the box at an amazing high-color depth. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle.
  • Full adjustability
  • All-digital connectivity
    Connect easily with other peripherals simultaneously, and view content from your handheld devices on the monitor screen - all without compromising picture quality. With DisplayPort, you can daisy-chain two monitors side by side by connecting via the DP-in and DP-out ports, eliminating the need to link every one of your monitors to the PC and reducing cable clutter. Charge or power USB devices with a high-speed USB 3.0 charging port. Connect to MHL compatible smartphone or tablet and display content directly on the larger monitor screen via MHL.
  • Eco-conscious design
Dell P2415Q - LED monitor - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class C
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
35 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.13725 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.664 cm x 20.5 cm x 36.953 cm
5.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8
Plug and Play, VESA EDID, DDC/CI
OptiPlex 3040
Display Type
Energy Class
Class C
52 kWh
35 W
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.13725 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
29 - 76 Hz
Horizontal Refresh Rate
31 - 140 kHz
Video Bandwidth
533.25 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, rotation, input select, colour temperature, uniformity, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), Energy Gauge, Energy Saver, Mercury free, Factory Calibration, Transition Minimised Differential Signaling (TMDS) technology, 82.09% (CIE 1931) colour gamut, 102.28% (CIE 1976) colour gamut
56.664 cm x 20.5 cm x 36.953 cm - with stand
5.4 kg
4 x USB 3.0 downstream , USB 3.0 upstream , MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output (MST) , Audio line-out
Mechanical
Tilt Angle
-5/+21
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
Power Supply
Internal
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.664 cm - depth: 20.5 cm - height: 36.953 cm - weight: 5.4 kg , Without stand - width: 56.664 cm - depth: 4.693 cm - height: 33.606 cm - weight: 3.34 kg
TCO Certified
35 °C
10 - 80% (non-condensing)
Dell OptiPlex 3040
B15V C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B15V C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.42
B15V C2G 5m Select High Speed HDMI with Ethernet In Stock £21.40
Response Time: 6ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 300 - 500
