The Dell 24 Monitor – P2414H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day.
- Dell P2414H - LED monitor - Full HD (1080p) - 23.8" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
- LED-backlit LCD monitor - 23.8"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 56.6 cm x 18 cm x 36.9 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- RoHS, CECP
- Bundled with
- 3-Years Advanced Exchange Service and Premium Panel Guarantee
- Display Type
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- HDCP
- 56.6 cm x 18 cm x 36.9 cm - with stand
- Bundled with
- DVI-D (HDCP) , DisplayPort , VGA , USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
- RoHS, CECP
- Security Slot Type
- Kensington security slot
- Input Voltage
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.89 |
