Dell P2314H 23" 1920x1080 VGA DVI DP USB LED Monitor
Quicklinx: 94SMWS00 Mfr#: 859-BBBI
Dell Professional series has productivity, performance and comfort, plus environmentally responsible design and power management features. It is recommended for large enterprises, health-care, education and other performance-driven organizations.
Dell P2314H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
LED-backlit LCD monitor - 23"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
54.58 cm x 18 cm x 36.3 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, RoHS, CECP, CEL
3-year warranty
Bundled with
Display Type
Diagonal Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
54.58 cm x 18 cm x 36.3 cm - with stand
Bundled with
DVI-D (HDCP) , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.58 cm - depth: 18 cm - height: 36.3 cm , Without stand - width: 54.58 cm - depth: 4.65 cm - height: 32.3 cm - weight: 3.34 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
94SM C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
