Dell P2222H - LED monitor - 22" (21.5" viewable) - 1920 x 1080 Fu
Quicklinx: GWT5WS00 Mfr#: DELL-P2222H
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£104.78 ex VAT
£125.73 inc VAT
A better view from anywhere. Stay productive no matter where you work. Reduce harmful blue light with this sleek 21.5-inch FHD monitor featuring ComfortView Plus technology.
Dell P2222H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/549695
Energy Class
Class D
Power Consumption (On mode)
11.8 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
48.726 cm x 17.957 cm x 48.199 cm
4.83 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
481 kg carbon emissions
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 Years Premium Panel Guarantee
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
LED edgelight system, Flicker Free technology, Mercury free, arsenic-free glass, Dell ComfortView Plus, 99% sRGB colour gamut
48.726 cm x 17.957 cm x 48.199 cm - with stand
4.83 kg
DisplayPort , VGA , HDMI , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable
Input Voltage
11.8 W
11.8 kWh/1000h
Power Consumption (Typical)
11.8 Watt
Power Consumption (Max)
46 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 48.726 cm - depth: 17.957 cm - height: 36.4 cm - weight: 4.83 kg , Without stand - width: 48.726 cm - depth: 5.215 cm - height: 28.999 cm - weight: 2.82 kg
Shipping Weight
6.37 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
105
Manufacturing (kg CO2e)
331.96
Logistics (kg CO2e)
32.7
Use (kg CO2e)
114
EOL (kg CO2e)
1.82
Total Carbon w/o Use Phase (kg CO2e)
367
PAIA Version
1.2.15, 2021
Bundled Services
10 - 80% (non-condensing)
GWT5 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.60
GWT5 Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £150.33
GWT5 Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £56.48
GWT5 Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
GWT5 Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £33.64
GWT5 Dell Dell Universal Dock In Stock £104.71
Diagonal Size: 22in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
